Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,333 Points: 22,306 Location: Northamptonshire, England
Issue 87
Front Panel Picture 1 show the parts for this issue. Fit the two front panel reinforcements as shown in picture 2. Now attach the two mounting brackets, picture 3.
Fit both the vacuum tank from issue 86 and the air conditioning unit from issue 87 onto the front panel as shown in pictures 4 and 5. Turn the assembly around and secure both in place using 2 x D screws, picture 6.
Turn the assembly back around and attach the hood lock from issue 85 and secure it in place using 2 x Q screws, picture 7.
Attach the two hood safety cables using a “O” screw for each side, picture 8. Push fit the two pins into the top of the panel and place the cable pin through the hole, picture 9.
Picture 10 shows the assembly complete for this issue.
Issue 88
Sun Visors Picture 1 show the parts for this issue. fit one of the sun visor rods into the top of the left lower part of the sun visor, picture 2. Place the upper left part over the assembly and push fit in place, picture 3. Do the same with the right sun visor parts, picture 4.
That complete the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 89
Headliner Picture 1 show the parts for this issue. Fit the two seat belts into the rectangular slots as shown in pictures 2 and 3.
Place the two sun visors into the headliner as illustrated in picture 4. Turn the assembly over as secure both using 2 x N screws for each visor, picture 5.
Issue 90
Body Shell In this stage we attach the two doors to the body, which is quite straight forward. Using 2 x type Q screws attach the doors as shown in picture 1.
Picture 2 shows the assembly complete for this issue.
Issue 91
Speaker Picture 1 show the parts for this issue. Install the speaker inside the body shell as shown in picture 2, using 2 x type F screws. Run the speaker cable along the channel and secure it using the speaker cable clip and a type A screw, picture 3.
Picture 4 shows the assembly complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 92
Taillights Picture 1 show the parts for this issue. Identify the left and right parts, pictures 2 and 3.
Place the both the right and left taillights into their corresponding housings, picture 4.
