World of Warcraft Lich King Pack 16 Options
#1 Posted : 04 October 2026 17:09:51
Issue 81
Picture 1 shows the contents of this issue. It also shows the parts in order of assembly.
Right Wrist Joint
Insert the shaft into the joint base and insert the shaft pin, picture 2. Place the spring over the rod then place them into the joint base as shown in picture 3. Place the joint base cover on top and secure it in place using pin nut and 2 x HM screws, picture 4.
Place the assembly into the wrist joint, picture 5, then secure it in place by attaching the support and fixing it in place using 3 x UP screws, picture 6.
Attach the wrist joint to the right forearm, picture 7 and secure it in place using 4 x KP screws, picture 8.
#2 Posted : 05 October 2026 19:37:56
Issue 82
Right Thumb and Shoulder Pad Support
Insert the shoulder pad support A inside the support B and place the smaller of the pins to hold them in place, picture 2. Next, place the shoulder pad joint on the told and hold it in place using the larger pin as shown in picture 3.
As you did with the previous hand, identify all the small finger and thumb segments. Take the thumb structure and place the first top three segment by push fitting the parts in place, picture 4. Do the same with the bottom segments, picture 5.
Picture 6 shows the completed assembly for this issue.
#3 Posted : 07 October 2026 13:48:33
Issue 83
Right Index and Middle Finger
As you did with the previous hand, identify all the index finger segments. Take the index structure and place the first top three segment by push fitting the parts in place, picture 2. Do the same with the bottom segments, picture 3.
Carry out the same process with the middle finger as shown in picture 4.
#4 Posted : 07 October 2026 14:02:52
Issue 84
Right Ring and Little Finger
As you did with the previous hand, identify all the ring and little finger segments. Take the structures and place the first top three segment by push fitting the parts in place. Do the same with the bottom segments., picture 2.
#5 Posted : 08 October 2026 11:25:03
Issue 85
Right Hand
Place the thumb into the palm of the right hand and secure it with an LP screw, picture 1.
Place the index and middle fingers into the hand, securing them both with LP screws, picture 2.
Next, place the ring and little fingers in the same way using LP screws, picture 3.
Picture 4 shows the completed assembly for this issue.
#6 Posted : 08 October 2026 11:34:52
Issue 86
Sword
Take the central plate B as shown in picture 2 and place it into the sword, picture 3.
Insert the light diffuser into the LED in the hilt body, picture 4, then insert the light rod into the hole in the diffuser as shown in pictures 5 and 6.
Finally, attach the central plate A to the sword, picture 7.
This page was generated in 3.140 seconds.
