 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,776 Points: 17,480 Location: ipswich
STAGE 112:
Reactor components.
Pic 1: Un-twist the centre section of the wires 112H and then position them in the grooves in bracket 112I and hold them in place with 112J as shown.
Pic 2: Fix the bracket to the reactor base with 2 x SM screws. Note the black component is at the top.
Pic 3: Connect the tube end of the wires to the red cylinder and base as indicated.
Pic 4: Fix the other end to the tank using 2 x AP screws.
Pic 5: Fix the component 112A to the base with 1 x AP screw from underneath.
Pic 6: Fix the components 2 x 112E to the base with 1 x AP screw from underneath in each.
Pic 7: Press-fit the pipe 112G in place as shown.
Pic 8: Assemble the parts 112B, 112C and 112D as shown.
Pic 9: Press-fit the pipe 112F in place where indicated.
Pic 10: Fix the assembly 112B/C/D in place where shown using 1 x BP screw from underneath.
Store safely for now.roymattblack attached the following image(s):
STAGE 113:
Reactor drum.
Pic 1: Loop the filament 113D and pass the ends through the hole in the drum 113A as shown.
Pic 2: On the inside, tape the filament ends up against the LED 113E as you have done before, using tape 113F.
Pic 3: Carefully pull the filaments through the hole and make a loop, so the filament sits in the groove around the edge of the drum. Fix the clear cover 113B in place to hold the filament securely and fix with 1 x BP screw from behind.
Pic 4: On the inside of the drum, secure the LED wire as shown using the clip 113C and 1 x IP screw.
STAGE 114:
Reactor drum.
Pic 1: Fit the detail parts 15 x 114A around the outside of the drum 113A. They will only fit one way.
Pic 2: Fix from underneath with 15 x CP screws.
Pic 3: Fit the cable through the reactor base as shown.
Pic 4: Reactor fitted.
Pic 5: Fix from underneath with 2 x BP screws.
Pic 6: Fit the LED wire into the groove under the base and fix the end with the clip 114B and 1 x KM screw.
STAGE 115:
Reactor components.
Pic 1: Press-fit the angled end of the cable 115E into the top of the mount 115D.
Pic 2: Fit the assembly on the base plate as shown.
Pic 3: Fix from underneath with 2 x EP screws.
Pic 4: Press-fit the connector 115A into the top of the mounts 115B and 115C. They should both have the holes on the outer face.
Pic 5: Fit the assembly to the base plate as shown.
Pic 6: Fix from underneath with 2 x EP screws.
Store safely.
STAGE 116:
Reactor drum cables.
Pic 1: For this stage you will find it far easier if you temporarily remove the assembly from the previous stage. Do not lose the screws.
Press-fit the straight connectors on the 4 x cables 116A into the locating holes shown.
Pic 2: Press-fit the other ends of the cables into the reactor drum as indicated. The upper cables go in the top holes, the lower cables in the bottom ones.
Pic 3: Re-fit the assembly to the base plate.
