Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,343 Points: 22,336 Location: Northamptonshire, England
Issue 81
Left Leg
Picture 1 shows the contents of this issue Fit the holes of the female strap (81-03) into the two upper left holes inside the right shin armour and place one of the plate washers over the holes and secure in place using 2 x X screws, pictures 2 and 3.
Now do the same with the other straps as illustrated in picture 4. Note: the packaging the individual straps come in are clearly marked with their part number for identification.
That completes the assembly for this stage.
Issue 82
Right Foot and Leg
Picture 1 shows the contents of this issue Retrieve the left and right leg assemblies and attach the two sections together as shown in picture 2.
Secure the assembly in place using 2 x F type screws to one side of the joint, and a further two F type screws to the opposite side as shown in pictures 3 and 4.
Picture 5 shows the assembly stage complete for this issue.
Issue 83
Right Foot
Picture 1 shows the contents of this issue Remove the protective film from one side of the adhesive, picture 2, and place it onto the counterweight, picture 3. Now remove the protective again, picture 4 and place the counterweight into the sole of the shoe as illustrated in picture 5.
Retrieve the upper shoe from issue 82 and fit it into the lower part, picture 6. Secure the two sections together using 7 x Y type screws, pictures 7 and 8.
Picture 9 shows the assembly stage complete for this issue.
Issue 84
Right Foot
Picture 1 shows the contents of this issue Remove the protective film on the rear heel piece and place it on the heel of the shoe, picture 2. Do the same with the front piece, picture 3.
Issue 85
Left Foot
Picture 1 shows the contents of this issue Remove the protective film from one side of the adhesive and place it onto the counterweight as you did with the previous shoe. Now remove the protective again and place the counterweight into the sole of the shoe as illustrated in picture 2.
Issue 86
Left Foot
As before with the right foot, place the two top and bottom halves of the show together, secure them using 7 x Y type screws, picture 1.
Picture 2 shows the assembly stage complete for this issue.
