Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,348 Points: 22,351 Location: Northamptonshire, England
Issue 1
Fuel tank and front Tyre
Picture 2 shows the contents of this issue Here we go with the Harley Davidson Fat Boy build. The first two pictures show the two magazine and contents of the first issue.
Store them away safely until they are needed in the future.
Issue 2
The Tail light
Picture 1 shows the contents of this issue Place the tail light base on the rear of the fender, then use a C type screw to secure it in place as shown in picture 2. Note, the circle is where the screw is placed as when taking the picture, I realised I had not inserted it.
Feed the LED and cable through the hole as shown in picture 3. Place the LED into the support ring and place the ring into the hole in the tail light base, pictures 4 and 5.
Take the black tape, supplied, and using three strips hold the cable in place on the underside of the fender as shown in picture 6.
Next, place the licence plate lens to the tail light unit, gently pushing it in place, picture 7.
Push the assembly in place on the fender as illustrated in picture 8.
Finally, push fit the two reflectors on the side of the fender, one on each side, pictures 9 and 10.
Picture 11 shows the assembly complete for this issue.
