Darth Vader Official Build Pack 17 Options
#1 Posted : 13 October 2026 16:20:15
Issue 87
Left Foot
Remove the protective film on the rear heel piece and place it on the heel of the shoe. Do the same with the front piece, picture 2.
That completes the assembly for this stage.
#2 Posted : 14 October 2026 16:01:28
Issue 88
Waist and Abdomen
Slot the friction disc into the seat support and secure in place using 4 x AA screws, picture 2.
Fit the assembly into the two seat blocks and secure in place using 4 x F screws one side and the same again the other side, pictures 3, 4 and 5.
#3 Posted : 14 October 2026 16:06:05
Issue 89
Waist and Abdomen
Fit the assembly into the lower waist block and secure in place using 2 x Y screws, picture 3.
Fit the mobile left arm of the support onto the assembly as shown in pictures 4 and 5.
#4 Posted : 14 October 2026 16:14:51
Issue 90
Waist and Abdomen
Fit the mobile left arm of the support onto the assembly as shown in picture 4.
Fit the assembly onto the assembly from issue 88 and secure in place using 4 x Q screws with four washers as shown in pictures 5 and 6.
Next rotate the assembly 90 degrees and fit the lower waist block, securing it in place using 4 x F screws, picture 7.
#5 Posted : 16 October 2026 12:53:10
Issue 91
Waist and Abdomen
Slot the friction disc into the waist support and secure in place using 4 x AA screws, pictures 2 and 3.
Next, fit the waist rotation support onto the friction disc and secure it in pace using 4 x Q screws with the washers, pictures 4 and 5.
Fit the assembly into the lower waist block and secure in place using 2 x Y screws, pictures 6 and 7.
Fit the assembly to the assembly you dis in issue 90 and secure in place using 5 x F screws one side as illustrated in picture 8 and 3 x F screws on the other side as shown in picture 9.
#6 Posted : 16 October 2026 13:01:39
Issue 92
Waist and Abdomen
Slot the friction disc into the waist support and secure in place using 4 x AA screws, picture 2.
Fit the waist assembly from the last issue onto the waist block, securing it in place using 2 x F screws, picture 3.
Next, fit the mobile support arm onto the friction disc, picture 4. Fit the assembly into the waist block. Turn the assembly over and secure in place using 2 x F screws, pictures 5 and 6.
Picture 7 shows the assembly stage complete for this issue.
This page was generated in 0.378 seconds.
