Darth Vader Official Build Pack 18 Options
#1 Posted : 16 October 2026 14:02:24
Issue 93
Waist and Abdomen
Slot the friction disc into the waist support and secure in place using 4 x AA screws, picture 2.
Next, fit the mobile support arm onto the friction disc, picture 3.
Fit the waist assembly from the last issue onto the waist block, picture 4, and keeping the piece in position, secure the entire assembly together using 5 x F screws, picture 5.
Turn the assembly over and secure in place another 5 x F screws, picture 6.
That completes the assembly for this stage.
#2 Posted : 16 October 2026 14:12:30
Issue 94
Waist and Abdomen
Fit the two waist supports together to form a ring and secure the two halves by using 2 x F screws, picture 2.
Fit the assembly into the lumbar waist, securing it with 4 x F screws, picture 3.
Fit the assembly onto the waist block as shown in picture 4, using 4 x F screws.
#3 Posted : 16 October 2026 14:19:43
Issue 95
Waist and Abdomen
Pass the cable through the hole of the abdomen and secure it by placing the wire guide clip over the wire guide, securing it in place by using 2 x F screws, pictures 2 and 3. Note the length of the cable.
Place the waist assembly onto the abdomen and secure it in place using 4 x F screws, picture 4.
#4 Posted : 16 October 2026 14:26:11
Issue 96
Waist and Abdomen
Retrieve the waist block and fit the rear waist piece using 3 x F screws, picture 2.
Fit the chest block onto the waist block, securing in place using 4 x F screws as shown in picture 3.
Retrieve the leg assembly and place the top of the leg block into the waist block, picture 4, then turning the assembly over secure it in place using 2 x F screws, picture 5.
Picture 6 shows the assembly stage complete for this issue.
#5 Posted : 16 October 2026 14:32:10
Issue 97
Waist and Abdomen
Fit the last chest block onto the abdomen and secure using 4 x F screws, picture 2.
Place an F type screw in the single hole on the chest block, turning it over and fixing another F screw as shown in picture 3.
Turn the assembly over and fit the front waist using 5 x F screws as illustrated in picture 4.
The final F screw is located on the lower part of the pelvis, picture 5.
#6 Posted : 16 October 2026 14:34:47
Issue 98
Chest
Fit the chest onto the abdomen section and secure it in place using 4 x F screws as shown in picture 2.
This page was generated in 0.203 seconds.
