 Rank: Newbie Groups: New Members, Unapproved Joined: 19/04/2023 Posts: 4 Points: 12 Location: uk
Part 35 Tested button lights and remote for sound nothing tested voltage 4.2vdc to board 3vdc to remote what should I do? Thanks Bob
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,805 Points: 17,567 Location: ipswich
Obviously you made sure the power switch to the board is on and batteries are the right way up/installed. Try unpluging and re-plugging all the leads, check the circuit board in the remote is installed the right way up. (I've seen that done incorrectly) If still nothing works, request a new car circuit board via CS.
Roy.
