 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,805 Points: 17,567 Location: ipswich
STAGE 93:
Front left wheel dry tyre.
Pic 1: Locate the wheel cover parts 93B and 93D. They will fit together as indicated. Fix the parts together with 2 x A screws.
Pic 2: Press the assembly into the front of the wheel 93A as shown.
Pic 3: Press-fit the centre ring 93C.
Store safely for now.
STAGE 94A:
Fuel filter and engine fitting.
Pic 1: Connect the tube 94C to the filter parts 94A and 94B as shown. Make sure you connect it to the correct pins.
Pic 2: Connect the tube 94E to the other pin on 94A.
Pic 3: Connect the tube 94D to the other pin on 94B.
Pic 4: Fit the assembly to the fuel tank 92A as shown. Connect the pipe 94D to the pin on the lower side of the tank.
Pic 5: Retrieve the engine and connect the pipe 94F as shown.
Pic 6: Fit the engine to the chassis as shown and fix with 1 x Y screw from underneath.
STAGE 94B:
Pic 7: Connect the tubes 94I and 2 x 94H as shown.
Pic 8: Retrieve the assembly 91A/B and connect the tubes 94I and 2 x 94H where shown.
Pic 9: Fit the assembly to the chassis as shown and fix from underneath with 2 x W screws.
Pic 10: Connect the pipes 94F and 19I where indicated.
Pic 11: Connect plug C to the circuit board.
Pic 12: Fit the hose 94G to the pin on the chassis where shown.
Pic 13: Connect the tube 94J to the two connections where shown.
STAGE 95:
Left side fairing.
Pic 1: Retrieve the assembly from stage 36 and fix it to the left side of the car chassis as shown using 2 x W screws from underneath.
Pic 2: Store everything safely for now.
