Toyota Supra F+F Issues 93 - 98 Options
#1 Posted : 19 October 2026 12:25:10
STAGE 93:
Front right wing and windscreen wipers.
Pic 1: Fix the right inner wing to the body with 3 x BM screws.
Pic 2: Fix the wipers 93D and 93E to the rain deflector 93B as shown with 2 x BP screws from behind.
Pic 3: Fit the assembly to the front of the body.
Pic 4: Fix from underneath with 4 x CP screws.
Pic 5: Peel the backing from the VIN plate 93C and fix it to the inner wing where indicated.
#2 Posted : 20 October 2026 12:53:37
STAGE 94A:
Front bumper.
Pic 1: Fit the horn 94D and bonnet release 94E into the front panel 94B as shown.
Pic 2: Fix the assembly to the front frame 94A with 2 x IM screws.
Pic 3: Fit the hood lock 94C as shown.
Pic 4: Retrieve the wires E, F and G.
Group the LED’s into threes so there are one of each LED in each group, with two spare G LED’s on their own.
Using some tape temporarily will help keep the LED’s together.
Pic 5: Retrieve the front frame and pass the groups of LED’s through the circular holes and then through the horizontal slot as shown.
The 2 x spare LED’s will remain free for now.
Make sure the plug ends of the wires are on the left as shown.
#3 Posted : 20 October 2026 12:56:08
STAGE 94B:
Pic 6: Retrieve the headlamps from stage 1 and connect the LED’s in the order shown.
Pic 7: With the assembly the other way up, fix the headlamps and clear covers with 2 x GM screws in each.
Pic 8: Another view of the fixings.
Pic 9: Use pieces of the silver foil tape 94F to hold the wires in place where shown.
Pic 10: Retrieve the front bumper from stage 1 and fit the LED’s from wire H as shown.
Pic 11: On the other side, fit the LED’s from wire C.
#4 Posted : 20 October 2026 12:57:51
STAGE 94C:
Pic 12: Use pieces of tape 94F to fix the wires down.
Pic 13: Do the same on the other side.
Pic 14: Plug the 2 x unused LED’s into the lights as shown.
Pic 15: Fit the assemblies together and fix with 3 x BM screws.
Take care to keep all the wires out of the way behind the central fixing.
Pic 16: Retrieve the body and fix the front bumper using 1 x WM and 1 x EM screw where shown.
Repeat on the other side.
Pic 17: Store the body safely for now.
#5 Posted : 21 October 2026 11:25:30
STAGE 95:
Boot panels and cylinders.
Pic 1: Fix the bracket 95D to the panel 95A with 1 x CP screw.
It will only fit one way.
Pic 2: Fix the bracket 95D to the panel 95B with 1 x CP screw.
Pic 3: Fix the cylinders 2 x 95H to the brackets 95E and 95F with 1 x HM screw in each.
Pic 4: Fix the assemblies to the rear of the body as shown with 1 x KM screw from underneath in each.
Pic 5: Press-fit the sill trim 95C in place.
Pic 6: Store everything safely for now.
#6 Posted : 22 October 2026 11:35:49
STAGE 96:
Doors and side panels.
Pic 1: Fit the door trim 96C.
Pic 2: Fit the left door to the car and fix with 2 x GM screws.
Builder’s tip – do not over tighten the screws as there is a chance the doors will not close properly if you do.
Pic 3: Use one of the plastic strips 96D to hold the door closed.
Alternatively, use a piece of low tack masking tape if you find the plastic strip doesn’t stick very well.
Pic 4: Fit the left wing in place and temporarily secure with low tack masking tape.
Pic 5: From the inside, fix with 5 x BM screws.
Pic 6: Repeat with the right door.
Pic 7: Repeat with the right front wing.
Pic 8: Fix with 5 x BM screws as shown.
Pic 9: Fix the inner boot panel 96B with 2 x MM screws.
Pic 10: Fix the inner boot panel 96A with 2 x MM screws.
#7 Posted : 23 October 2026 10:37:44
STAGE 97:
Tail light housings.
Pic 1: Press-fit the housing parts 97B, 97D, 97C and 97E together as shown.
Pic 2: Fix the housings to the rear panel 97A where indicated with 1 x AP screw in each from behind.
Store safely for now.
This page was generated in 0.367 seconds.
