Ferrari F1-2000 Official build Stages 33 - 38 Options
#1 Posted : 19 October 2026 13:32:07
STAGE 33:
Remote control 2.
Pic 1: Retrieve the assembly from stage 32.
The circuit board 33B will fit inside with the silver contacts facing the rubber buttons.
Pic 2: Circuit board installed.
Pic 3: Clip the back cover 33A in place and then fit the battery holder 33C.
The remote control will need 1 x CR2032 battery – not supplied.
Pic 4: Store safely for now.
#2 Posted : 20 October 2026 16:54:03
STAGE 34:
Circuit board.
Pic 1: Fit the plug on wire 34B into the ‘B’ socket on the circuit board 34A.
#3 Posted : 21 October 2026 12:55:35
STAGE 35:
Electrical components.
Pic 1: Retrieve the circuit board from the previous stage and connect the battery box plug A to the matching socket on the board.
Pic 2: Connect the speaker plug D to the matching socket on the board.
Pic 3: Connect wire C and the extension wire together
Pic 4: Connect the extension wire plug C to the matching socket on the board.
You can now add batteries to the battery box and the remote control to test that all the functions work.
#4 Posted : 22 October 2026 13:00:55
STAGE 36:
Intake box.
Pic 1: The intake box 36A will attach to the top of the engine using small magnets to keep it in place, so that is removable.
Pic 2: Airbox installed.
Store the engine safely for now.
#5 Posted : 23 October 2026 10:59:53
STAGE 37:
Gearbox 1.
Pic 1: Fix the bracket 37B to the side of the gearbox 37A where shown using 1 x QM screw.
It will only fit one way.
This page was generated in 0.162 seconds.
