Red Bull RB19 Official build. Stages 93 - 98 Options
#1 Posted : 19 October 2026 12:38:55
STAGE 93:
Front left wheel dry tyre.
Pic 1: Locate the wheel cover parts 93B and 93D.
They will fit together as indicated.
Fix the parts together with 2 x A screws.
Pic 2: Press the assembly into the front of the wheel 93A as shown.
Pic 3: Press-fit the centre ring 93C.
Store safely for now.
#2 Posted : 20 October 2026 15:49:23
STAGE 94A:
Fuel filter and engine fitting.
Pic 1: Connect the tube 94C to the filter parts 94A and 94B as shown.
Make sure you connect it to the correct pins.
Pic 2: Connect the tube 94E to the other pin on 94A.
Pic 3: Connect the tube 94D to the other pin on 94B.
Pic 4: Fit the assembly to the fuel tank 92A as shown.
Connect the pipe 94D to the pin on the lower side of the tank.
Pic 5: Retrieve the engine and connect the pipe 94F as shown.
Pic 6: Fit the engine to the chassis as shown and fix with 1 x Y screw from underneath.
#3 Posted : 20 October 2026 15:51:34
STAGE 94B:
Pic 7: Connect the tubes 94I and 2 x 94H as shown.
Pic 8: Retrieve the assembly 91A/B and connect the tubes 94I and 2 x 94H where shown.
Pic 9: Fit the assembly to the chassis as shown and fix from underneath with 2 x W screws.
Pic 10: Connect the pipes 94F and 19I where indicated.
Pic 11: Connect plug C to the circuit board.
Pic 12: Fit the hose 94G to the pin on the chassis where shown.
Pic 13: Connect the tube 94J to the two connections where shown.
#4 Posted : 21 October 2026 18:40:56
STAGE 95:
Left side fairing.
Pic 1: Retrieve the assembly from stage 36 and fix it to the left side of the car chassis as shown using 2 x W screws from underneath.
Pic 2: Store everything safely for now.
#5 Posted : 22 October 2026 13:39:03
STAGE 96:
Front left wheel – Dry tyre.
Pic 1: Retrieve the wheel from stage 93.
The tyre 96A will fit onto it.
You may find it easier to fit the tyre if you soak it in hot water for a few minutes.
Dry the tyre inside and out and press it onto the wheel rim.
Take care with hot water.
The use of hot water is at the builder’s discretion.
Store everything safely.
#6 Posted : 23 October 2026 11:17:24
STAGE 97:
Right side fairing.
Pic 1: Retrieve the assembly from stage 40 and fix it to the right side of the car chassis as shown using 2 x W screws from underneath.
This page was generated in 0.251 seconds.
