 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
STAGE 63:
Fuel tank hoses.
Pic 1: As you did before with the other fuel lines, feed the 4 x washers 63-4 over the hose 63-1, keeping them equally spaced along the hose. Then feed the 2 x smaller tubes 63-2 through the outer holes in each washer.
Pic 2: Fit the fuel filler neck 63-3 as shown, paying attention to where the hose and tubes connect.
Store safely for now.
STAGE 64:
Steering frame.
Pic 1: Fix the column parts 64-2 and 64-3 together with 1 x A screw as shown.
Pic 2: Fit the column into the frame 64-1 and fix the cover 64-4 over it using 2 x D screws.
Store safely for now.roymattblack attached the following image(s):
