Bugatti Veyron official build Stages 3 - 8 Options
#1 Posted : 04 November 2026 15:13:44
STAGE 3:
Front left wheel.
Pic 1: Fix the wheel rim parts 3C and 3B together using 3 x DS02 screws.
Pic 2: Fit the tyre 3A to the rim.
You will find it far easier if you soak the tyre in hot water for a few minutes and then dry it inside and out.
Make sure the side of the tyre with the smaller tread pattern as highlighted is on the outside of the wheel.
Pic 3: Store everything safely for now.
#2 Posted : 05 November 2026 14:45:34
STAGE 4:
Right door and mirror.
Pic 1: Fix the door handle 4C to the door 4A with 1 x PS05 screw.
Pic 2: Press-fit the mirror parts 4B and 4D together.
Pic 3: Fit the mirror to the door as shown.
Pic 4: Fix from the inside with 1 x DS02 screw.
Store safely.
#3 Posted : 06 November 2026 11:21:49
STAGE 5:
Right door window and lock.
Pic 1: Retrieve the door from the previous stage and fix the window 5A in place with 3 x DS02 screws.
Pic 2: Slide the spring 5G over the short end of the lock bolt 5D.
Pic 3: Locate the fixing brackets 5E and 5F.
Note they are different widths and 5F has the holes nearer one edge.
Pic 4: Fit the bolt 5D into the recess in the side of the door with the spring on the inside.
Fix the brackets 5E and 5F in place as shown using 2 x DS03 screws in each.
Pic 5: Fix the hinge parts5B and 5C to the other end of the door using 1 x DS05 screw.
Note the orientation of the bracket 5C, highlighted in grey.
Store safely for now.
This page was generated in 0.342 seconds.
