Issue 87 Part 1
Picture 1 shows the contents of this issue. Sword Install the blade plate “B” as shown in pictures 2,3 and 4. Turn the assembly over and secure it in place using 2 x LP screws, picture 5. Next, install plate “A” by push fitting it in place, picture 6.
Insert the horns of the ornamental skull as shown in picture 7 and secure in place using 2 x PP screws, picture 8.
Take off the two hilt guards from the sword. This will facilitate the next assembly, picture 9.
Place the diffuser from issue 86 and insert into the skull, picture 10. Place the assembly onto the sword by push fitting it into place, make sure the horns are over the hilt, picture 11.
Place the two hilt guards back in place on the hilt, picture 12.
That completes part 1 of the assembly for this issue.
Issue 87 Part 2
Sword Insert the horns on the second ornamental skull and secure in place using 2 x PP screws, pictures 13 and 14. Place the diffuser into the skull, picture 15.
Push fit the assembly onto the sword as shown in picture 16.
Take the guard ornaments and push fit them both in place on the end of the hilt. Note: Observe the shape of the notch to position them correctly, pictures 17, 18 and 19.
Finally, Snap in place the two blade ornaments, picture 20.
Tip: I used a small dab of glue to hold them in place.
Picture 21 shows the completed assembly for this issue.
Issue 88
Pourpoint Picture 1 shows the parts for this issue. To get the pourpoint on the figurine, lift the arms and slide the sleeves in place then finally bring the two halves together with the Velcro, picture 2 and 3.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
