Iron Spiderman Official Build Issues 75 - 80 Options
#1 Posted : 04 November 2026 18:50:46
Issue 75
The Left Leg
Picture 1 show the parts for this issue
Fit the left heel gold detail inside the left heel and secure it in place using 2 x E screws, picture 2.
Fit the assembly onto the back of the left sole and secure using 2 x E screws, picture 3.
Picture 4 shows the assembly complete for this issue.
#2 Posted : 06 November 2026 16:13:06
Issue 76
The Left Leg
Retrieve the right foot assembly from issue 75 and fit the foot mount inside and secure it in place with 2 x type P screws using the M4 Allen key, picture 2.
Position the left foot post over the foot mount making sure the arrow, as shown in picture 3, is pointing upwards.
Fit the inner structure of the foot on the side of the post, picture 4. Fasten the foot structure with a type J screw and two M3 hexagonal anti slip nuts and Type R screws on the other side, pictures 5, 6 and 7.
Finally, reinforce the joint by attaching a type J screw through the sole as shown in picture 8.
Picture 9 shows the assembly complete for this issue.
#3 Posted : 07 November 2026 13:03:09
Issue 77
The Left Leg
Retrieve the right foot assembly from issue 76 and fit the left knee attachment as shown in picture 2 with the arrow facing upwards. Secure the knee attachment by pushing the screws through the hole with an M3 nut on the opposite side of the hole, pictures 3 and 4.
Now fit the left leg frame, securing it in place using type R screw with toothed washer and an M3 nut, pictures 5, 6, 7 and 8.
At the base of the right inner foot cover, fit the gold detail as shown in picture 9. Fix the right leg inner cover onto the frame, picture 10, and secure in place using 4 x type E screws as illustrated in picture 11.
Finally, secure the top part of the leg cover using a type E screw, picture 12.
Picture 13 shows the assembly complete for this issue.
#4 Posted : 08 November 2026 13:50:14
Issue 78
The Left Leg
On the inside of the right leg outer cover, position and fit the gold detail, securing it in place with a type E screw, pictures 2 and 3. Push the right foot outer frame into the outer cover and secure it using 3 x type E screws, picture 4.
Retrieve the right leg assembly and fit it into the outer frame, picture 5. Holding the parts together, place a J screw into the foot as illustrated in picture 6. Place 2 x F screws as shown in picture 7. Fit another type J screw into the sole, picture 8. Fit two more type J screws as shown in picture 9.
On the back of the leg, push fit the lower calf cover, pictures 10. Press the right foot top cover into the correct position, it is best to fit it starting from the toe. Secure in place using a type F screw, picture 11, followed by a type E screw as shown in picture 12.
Press the toe cap into place, pushing in the centre to secure it in position, picture 13. Finally, Place an E type screw in the shin, picture 14.
Picture 15 shows the assembly complete for this issue.
#5 Posted : 09 November 2026 13:59:08
Issue 79 Part 1
The Left Leg
Push the leg post into the knee attachment, making sure the arrow is pointing upwards as illustrated in picture 2. Secure it in place using 2 x type Q screws and 2 x M4 nuts, picture 3.
On the outside of the left calf frame, position and fit the calf gold detail, securing it using 2 x type E screws, picture 4. Place the blue calf plate above the gold detail and fix it in place using a type E screw, picture 5. Now fix the next gold detail in place, picture 6. Turn the assembly over and place 2 x type F screws to secure it in place, picture 7.
Plug the right leg LED cable into the connector in the right leg circuit board, picture 8. The fit the circuit board to the recess in the side of the shin frame, securing it with a type E screw, pictures 9 and 10.
That completes part 1 of this issue.
#6 Posted : 09 November 2026 14:02:45
Issue 79 Part 2
The Left Leg
Position the right LED cover inside the blue shin plate, picture 11. Place the assembly over the right shin frame and secure using a type E screw, pictures 12 and 13. Next, fit the upper gold detail, securing it from the inside with 2 x type F screws.
Take the calf assembly and fit it to the right leg, securing it using 2 x type G screws, pictures 14 and 15. Now attach the shin piece to the leg, securing it in place using 2 x type G screws, pictures 16 and 17. Finish the assembly with two type E screws at the rear of the leg, picture 18.
Picture 19 shows the assembly complete for this issue.
#7 Posted : 11 November 2026 13:18:26
Issue 80
The Left Leg
Retrieve the right leg assembly from the previous issue and fit the left shin cover, picture 2.
On the outside of the leg, fit the two gold details and secure both in place using 2 x type E screws for each one, picture 3. Repeat the step for the gold details on the inside of the leg, picture 4.
Now fit the inner back cover securing it using a type S screw, picture 5. Do the same with the outer back cover, picture 6.
On the inner pins of the central back cover, place a magnet and tighten 2 x type I screws to hold the magnets in position, picture 7. Note: DO NOT over tighten as you will damage the magnets. Now fit the central cover in place on the back of the leg assembly, picture 8.
This page was generated in 2.691 seconds.
