Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,412 Points: 22,546 Location: Northamptonshire, England
Issue 105
Head
Picture 1 shows the contents of this issue. Note: This head is used when you do not want the helmet in place on the figure.
Picture 2 shows the assembly stage complete for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 106
Uniform
Picture 1 shows the contents of this issue. Remove both the left and right hands from Darth Vader figurine. Fit the right glove onto the hand. Tip: it is easier to put on with the glove sleeve folder back, pictures 2, 3 and 4. Do the same with the left hand, picture 5.
Place the inner protective mesh vest onto the torso of Darth Vader, picture 6.
That completes the assembly for this stage.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 107
Uniform
Picture 1 shows the contents of this issue. Place the two inner protective mesh trouser parts to the legs. Start with the left side, picture 2 and then the right part, attaching the two sections with the Velcro, picture 3.
Issue 108
Uniform
Picture 1 shows the contents of this issue. Fit the outer vest onto the torso, from behind and attach the Velcro, picture 2.
Attach the left-hand sleeve so it is snug over the shoulder and so there is no separation between the vest and arm, picture 3.
Issue 109 and 110
Uniform
Picture 1 shows the contents of this issue. In this section, I have combined issue 109 with 110 as it is easier to attach both the trousers’ sections. Issue 109 you receive the left-hand trousers with the right-hand trousers with issue 110.
Fit both the trouser sections as you did with the inner trouser sections, by attached the two parts with the Velcro, pictures 2 and 3.
Now we attach the two feet. First, if you have placed the heel plate, please remove them to access the hole for the screws, picture 4. Place the left foot onto the leg and secure it in place using 2 x EE screws. Note: because of the depth of the hole in the heel, attaching the screws can be difficult. I would recommend a good strong magnetic screwdriver for this process, picture 5. Do the same with the right foot and then reattach both the heel plates, picture 6.
