Darth Vader Official Build Pack 21 Options
#1 Posted : 09 November 2026 15:54:17
Issue 111
Uniform
Place the right sleeve on the arm of Darth Vader as you did in issue 108 with the left sleeve, picture 2.
Add the boot shaft and fasten it with the Velcro. Make sure the Velcro is on the inside of the leg, picture 3.
Picture 4 shows the assembly stage complete for this issue.
#2 Posted : 12 November 2026 15:59:00
Issue 112
Uniform
Place the vest onto Darth Vader and fasten it using the Velcro, pictures 2 and 3.
Retrieve the chest panel from issue 34 and place it on his chest as illustrated in picture 4 and 5.
Picture 6 shows the assembly stage complete for this issue.
#3 Posted : 12 November 2026 16:01:53
Issue 113
Uniform
Attach the two parts of the cape together with the Velcro, picture 2.
That completes the assembly for this stage.
#4 Posted : 12 November 2026 16:03:49
Issue 114
Uniform
Attach the right boot shaft as you dis before with the left boot shaft, picture 2.
#5 Posted : 12 November 2026 16:08:10
Issue 115
Uniform
Retrieve the left and right shins you assembled in issues 80 and 81, picture 2. Fit them to the front of the boot shafts and fasten the straps at the back of the leg, picture 3.
#6 Posted : 12 November 2026 16:34:36
Issue 116
Uniform
Fit the two side codpiece belts using 2 x GG screws and the plastic washer, picture 2. Fit the central belt in the same way, picture 3. Picture 4 shows all three belts in place on the codpiece.
Fit the codpiece to Darth Vader as shown in picture 5 securing the straps at the back.
Retrieve the cape you worked on in issue 113 and pull it on over the arms and onto the figure, picture 6.
Fit both the hands back onto Darth Vader, picture 7.
Now fit the waist belt to the figure. Note: If you haven’t already done so, place the three batteries into the unit of the belt and make sure the switch is in the on position before using the remote control at the end of the build.
Make sure the two cables are connected as shown in picture 8.
Picture 9 shows the assembly stage complete for this issue.
This page was generated in 2.495 seconds.
