 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,855 Points: 17,717 Location: ipswich
STAGE 3:
Front left wheel.
Pic 1: Fix the wheel rim parts 3C and 3B together using 3 x DS02 screws.
Pic 2: Fit the tyre 3A to the rim. You will find it far easier if you soak the tyre in hot water for a few minutes and then dry it inside and out. Make sure the side of the tyre with the smaller tread pattern as highlighted is on the outside of the wheel.
Pic 3: Store everything safely for now.
STAGE 4:
Right door and mirror.
Pic 1: Fix the door handle 4C to the door 4A with 1 x PS05 screw.
Pic 2: Press-fit the mirror parts 4B and 4D together.
Pic 3: Fit the mirror to the door as shown.
Pic 4: Fix from the inside with 1 x DS02 screw.
Store safely.
STAGE 5:
Right door window and lock.
Pic 1: Retrieve the door from the previous stage and fix the window 5A in place with 3 x DS02 screws.
Pic 2: Slide the spring 5G over the short end of the lock bolt 5D.
Pic 3: Locate the fixing brackets 5E and 5F. Note they are different widths and 5F has the holes nearer one edge.
Pic 4: Fit the bolt 5D into the recess in the side of the door with the spring on the inside. Fix the brackets 5E and 5F in place as shown using 2 x DS03 screws in each.
Pic 5: Fix the hinge parts5B and 5C to the other end of the door using 1 x DS05 screw. Note the orientation of the bracket 5C, highlighted in grey.
Store safely for now.
STAGE 6:
Right door inner panel.
Pic 1: Press-fit the window bracket 6B into the top front of the panel 6A.
Pic 2: Fit the panel to the door from the previous stage and fix with 3 x DS02 screws.
STAGE 7:
Rear spoiler.
Pic 1: With the spoiler 7A upside down, fit the brackets 7B – R and 7C – L in place where shown. Each bracket is marked ‘L’ and ‘R’. Fix with 1 x PS06 screw in each.
Pic 2: Store safely for now.
STAGE 8:
Door armrest.
Pic 1: Fix the window switch 8D to the armrest 8A with 1 x PS05 screw from the other side.
Pic 2: Fix the door lock 8C to the door handle 8B with 1 x PS07 screw from the other side.
Pic 3: Press-fit the arm rest assembly into the inner door panel as shown.
Pic 4: Press-fit the door handle assembly into the inner door panel as shown.
