Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,412 Points: 22,546 Location: Northamptonshire, England
Issue 87 Part 1
Picture 1 shows the contents of this issue. Sword Install the blade plate “B” as shown in pictures 2,3 and 4. Turn the assembly over and secure it in place using 2 x LP screws, picture 5. Next, install plate “A” by push fitting it in place, picture 6.
Insert the horns of the ornamental skull as shown in picture 7 and secure in place using 2 x PP screws, picture 8.
Take off the two hilt guards from the sword. This will facilitate the next assembly, picture 9.
Place the diffuser from issue 86 and insert into the skull, picture 10. Place the assembly onto the sword by push fitting it into place, make sure the horns are over the hilt, picture 11.
Place the two hilt guards back in place on the hilt, picture 12.
That completes part 1 of the assembly for this issue.
Issue 87 Part 2
Sword Insert the horns on the second ornamental skull and secure in place using 2 x PP screws, pictures 13 and 14. Place the diffuser into the skull, picture 15.
Push fit the assembly onto the sword as shown in picture 16.
Take the guard ornaments and push fit them both in place on the end of the hilt. Note: Observe the shape of the notch to position them correctly, pictures 17, 18 and 19.
Finally, Snap in place the two blade ornaments, picture 20.
Tip: I used a small dab of glue to hold them in place.
Picture 21 shows the completed assembly for this issue.
Issue 88
Pourpoint Picture 1 shows the parts for this issue. To get the pourpoint on the figurine, lift the arms and slide the sleeves in place then finally bring the two halves together with the Velcro, picture 2 and 3.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 89
Chainmail
Picture 1 shows the contents of this issue. To get the chainmail on the figurine, lift the arms and slide the sleeves in place as you did with the pourpoint, pictures 2 and 3. Make sure the four holes in the shoulders and top frame align with the pegs. Note: Mine did not have any holes in the bottom back section as stated.
Place the right shoulder pad support from issue 82 and secure it in place using an EM screw as shown in picture 4. Do the same with the left shoulder pad support, picture 5.
Attach the left hand from issue 74 to the left wrist. Place the wrist joint on and secure them by using 2 x LP screws, picture 6. Fit the back of the hand on and secure this in place using 4 x LP screws as shown in picture 7. Do the same with the right hand.
Picture 8 shows the completed assembly for this issue.
Issue 90
The Lower Back Armour and Fastening Belt
Picture 1 shows the contents of this issue. Note: As stated in the previous section, the chain =mail did not have any holes in the back. This next section I moved the chainmail above the pegs to fit the armour in place.
Fit the lower back armour onto the pegs and secure it in place using 2 x LP screws, picture 2. Once in place attach the fastening belt by using 2 x GP screws as shown in picture 3.
Issue 91
Armoured Belt
Picture 1 shows the contents of this issue. Retrieve the parts from issues 51 and 54. Place the figurine on a flat surface and attach the outer protections to the right leg, Issue 51, and the left leg, issue 54. Secure both in place by attaching the parts into the protruding pegs on each thigh and secure using 2 x SP screws, pictures 2 and 3.
Retrieve the ends of the spines from issues 51 and 54. The parts are labelled R1, R2, L1 and L2, pictures 4, 5, 6 and 7.
At the rear secure the straps by fitting them around the thigh, pictures 8 and 9
Picture 10 shows the completed assembly for this issue.
Issue 92
Fauld Picture 1 shows the contents of this issue. Fit the holes of the Fauld and the side straps onto the pegs on the armoured belt as shown in picture 2.
Insert the inner frame of the Fauld into the armoured belt and secure in place using 2 x LP screws on the upper central pegs and 2 x GP screws on the lower central pegs, picture 3.
Picture 4 shows the assembly complete.
The last two pictures show the parts assembled in this pack on the figurine.
