 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,855 Points: 17,717 Location: ipswich
STAGE 63:
Fuel tank hoses.
Pic 1: As you did before with the other fuel lines, feed the 4 x washers 63-4 over the hose 63-1, keeping them equally spaced along the hose. Then feed the 2 x smaller tubes 63-2 through the outer holes in each washer.
Pic 2: Fit the fuel filler neck 63-3 as shown, paying attention to where the hose and tubes connect.
Store safely for now.
STAGE 64:
Steering frame.
Pic 1: Fix the column parts 64-2 and 64-3 together with 1 x A screw as shown.
Pic 2: Fit the column into the frame 64-1 and fix the cover 64-4 over it using 2 x D screws.
Store safely for now.roymattblack attached the following image(s):
STAGE 65:
Steering rod.
Pic 1: Locate the steering rack ends 65-2 (R) and 65-3 (L) They are marked L and R – Left and Right. Fit the rubber boots 2 x 65-5 over the parts as shown.
Pic 2: Fit the assemblies to the steering rod 65-1 in the positions indicated. Note the toothed part of the rod is on the right.
Pic 3: Fix the parts in place using 65-4 and 1 x C screw. Repeat on the other side.
Pic 4: Slide the rubber boot in place as shown.
Pic 5: Retrieve the chassis assembly and fit the rod in place as indicated noting where the toothed section is. Rod highlighted in yellow.
Pic 6: Fix the rod end to the hub using 1 x G screw. Repeat on the other side.
Pic 7: Store safely for now.
STAGE 66:
Steering lock.
Pic 1: Retrieve the chassis assembly and fit the 2 x brackets 66-3 over the rod as shown.
Pic 2: Fix from underneath with 2 x D screws in each.
Pic 3: Retrieve the frame assembly from stage 64 and fit it in place as shown. Make sure the wheel hubs are facing straight forward, and the flat face on the end of the steering column is facing up. Fix with 4 x D screws.
Pic 4: Store everything safely for now.
STAGE 67:
Rear turbine housing.
Pic 1: Press-fit the turbine reinforcing 67-4 into place on the housing 76-1.
Pic 2: Press-fit the protective plate 67-5 in place where shown.
Pic 3: Fit the two halves of the oil pump 67-2 and 67-3 together.
Pic 4: Fix the assembly to the housing as shown with 1 x D screw from underneath.
STAGE 68:
Rear turbine engine 1.
Pic 1: Press-fit the air duct parts 68-1 and 68-2 together. They will only fit one way.
Pic 2: Fit the connector 68-4 to the assembly from stage 67 as shown.
Pic 3: Connect the hose 68-3 as indicated.
Pic 4: Fix the air duct in place with 2 x D screws from underneath.
Pic 5: Assemble the left air filter parts 68-8, 68-9, 68-7, 68-6 and 68-5 in the order shown.
Pic 6: Fix the assembly in place with 1 x E screw underneath.
