 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,862 Points: 17,738 Location: ipswich
STAGE 99:
Front right wheel dry tyre.
Pic 1: Locate the wheel cover parts 99B and 99D. They will fit together as indicated. Fix the parts together with 2 x A screws.
Pic 2: Press-fit the centre ring 99C.
Pic 3: Press the assembly into the front of the wheel 99A as shown.
Store safely for now.
STAGE 100:
Seat belts.
Pic 1: Retrieve the belts from stage 98 and fit them to the outer pins on the catch 100B. Note the tab is at the top.
Pic 2: Fit the belts 100D and 100E as shown. Note the longer ends of the upper brackets are facing inwards.
Pic 3: Detail of centre catch.
Pic 4: Press-fit the locking cover 100C in place.
Pic 5: Fix the upper belt brackets to the seat using 1 x G screw in each.
Pic 6: With the seat upside down, fix the lower belts as shown with 1 x Z screw.
Pic 7: Press-fit the head rest 100A in place.
