Ferrari F1-2000 Official build Stages 39 - 44 Options
#1 Posted : 17 November 2026 11:06:58
STAGE 39:
Left rear suspension 2.
Pic 1: Fit parts 39A and 39C together as shown.
Note the orientation of the bracket on 39C highlighted in yellow.
Pic 2: Fix 39B in place with 1 x NP screw.
Pic 3: Fix the assembly to the bracket on the gearbox part from the previous stage using 1 x AM screw.
Pic 4: View from the other side.
Pic 5: Fit the hose 39D to the two pins as indicated.
Store safely for now.
#2 Posted : 18 November 2026 13:14:55
STAGE 40:
Left rear suspension.
Pic 1: Fix the axle support 40C into the gearbox part 37A as shown using 2 x QM screws.
Pic 2: Retrieve the engine and place it upside down in the position shown.
Pic 3: Fix the gearbox assembly in place using 1 x CM screw.
Pic 4: Slide the boot 40B over the shaft 40A.
Pic 5: Fit the shaft into the gearbox.
This page was generated in 0.207 seconds.
