 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
STAGE 99:
Left Window net.
Pic 1: Carefully fit the net rods 99C and 99D to the net 99B as shown.
Pic 2: Fit the long rod 99D on the net into the locations on the interior as shown. Make sure the net is the correct way round.
Pic 3: Fit the shorter hooked rod 99C in place where indicated.
Pic 4: Fit the roll cage bar 99A in place as indicated. Highlighted in yellow. You will find it easier to temporarily remove the black interior vent hose to do this.
Pic 5: This shows the location of the front of the bar. Highlighted in yellow.
Pic 6: Fix from underneath with 2 x AP screws.
Pic 7: Replace the air vent hose.
Store safely for now.roymattblack attached the following image(s):
STAGE 100:
Roll cage rear braces.
Pic 1: Fix the brackets 100B and 100C to the brace 100A with 1 x TP screw underneath in each. The brackets are marked ‘L’.
Pic 2: Fit the assembled brace to the rear left of the roll cage as shown and fix with 1 x AP screw in each end.
Pic 3: Fix the brackets 100D and 100C to the brace 100E with 1 x TP screw underneath in each. The brackets are marked ‘R’.
Pic 4: Fit the assembled brace to the rear right of the roll cage as shown and fix with 1 x AP screw in each end.
