Ducati Desmosedici GP23 Issues 57 to 62 Options
#1 Posted : 20 November 2026 13:32:12
Issue 5 Part 1
Fit the right front fender bracket and secure it in place using 2 x AM screws. Now do the same with the left-hand fender bracket, pictures 2 and 3.
Turn the model over so the right side is facing you. Attach the front fender from issue 2 making sure you clip the mounting discs on their posts, picture 4. Once in place apply a KM screw in the hole on the top of the fender on both sides as shown in pictures 5 and 6.
That completes the assembly for Part 1 of this issue.
#2 Posted : 20 November 2026 13:34:14
Issue 57 Part 2
Retrieve the front wheel assembly you built early in the build and feed the wheel between the two forks, pushing the brake disk between the brake discs, pictures 7 and 8.
Take the front wheel axle and place it through the forks on the right-hand side as shown in pictures 9 and 10. Turn the bike over and secure the wheel using the axle bold, picture 11.
Turn the model back onto the right side and push fit the front brake calliper as illustrated in pictures 12 and 13.
Position the fork bridge over the holes in the calliper mounting and secure it in place using 2 x KM screws, picture 14. Attach a KP screw to the rear of the calliper, picture 15.
Connect the tube 48-0-2 to the calliper as shown in picture 16.
This page was generated in 0.038 seconds.
