 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,873 Points: 17,771 Location: ipswich
STAGE 99:
Rear window and hinges.
Pic 1: Retrieve the tailgate 99A and fix the hinges 99C and 99D in place with 2 x BM screws in each. Make sure you fit each hinge on the correct side as shown.
Pic 2: Fit the rear window 99A by sliding the lower tabs in place first and then clicking the upper tabs in place. The tab locations are highlighted in yellow.
Pic 3: Fix the screen with 2 x QM screws on the inside.
Pic 4: Store everything safely for now.
STAGE 100:
Tailgate inner frame.
Pic 1: The following four steps are fitting the spoiler support brackets. Look closely at the sprue of brackets and you will see they are all numbered 1 – 8. It is important that you fit the correct brackets in each space and fix underneath with 1 x KP screw in each. This step uses 100B-1 and 100B-5.
Pic 2: 100B-2 and 100B-3.
Pic 3: 100B-6 and 100B-7.
Pic 4: 100B-5 and 100B-8.
Pic 5: Fix pieces of self-adhesive tape 100C where shown.
Pic 6: Fix the LED wire in place as indicated.
Pic 7: Fix the frame 100A using 4 x IM and 2 x QM screws where indicated.
Pic 8: Fix the lower panel 99B using 4 x QM screws.
Store safely for now.roymattblack attached the following image(s):
STAGE 102:
Rear spoiler.
Pic 1: Lay the spoiler 102A in the position shown. Fix the left brackets 102F using 1 x PP screw in each. The parts are marked 'L'. NOTE – The thicker bracket goes toward the other half of the spoiler. Fix the right brackets 102E using 1 x PP screw in each. The parts are marked 'R'. Again, the thicker bracket goes toward the other half of the spoiler.
Pic 2: Fix the 2 x supports 102D using 2 x VM screws in each. Note the direction of the supports as indicated in yellow.
Pic 3: Fix the end plate 102C using 4 x PP screws. Note the direction of the spoiler support indicated in yellow.
Pic 4: Fix the other support in the same way.
