 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,876 Points: 17,780 Location: ipswich
STAGE 99:
Front right wheel dry tyre.
Pic 1: Locate the wheel cover parts 99B and 99D. They will fit together as indicated. Fix the parts together with 2 x A screws.
Pic 2: Press-fit the centre ring 99C.
Pic 3: Press the assembly into the front of the wheel 99A as shown.
Store safely for now.
STAGE 100:
Seat belts.
Pic 1: Retrieve the belts from stage 98 and fit them to the outer pins on the catch 100B. Note the tab is at the top.
Pic 2: Fit the belts 100D and 100E as shown. Note the longer ends of the upper brackets are facing inwards.
Pic 3: Detail of centre catch.
Pic 4: Press-fit the locking cover 100C in place.
Pic 5: Fix the upper belt brackets to the seat using 1 x G screw in each.
Pic 6: With the seat upside down, fix the lower belts as shown with 1 x Z screw.
Pic 7: Press-fit the head rest 100A in place.
STAGE 101:
Cockpit 2.
Pic 1: Retrieve the cockpit assembly and press-fit the side panel 101B in place. Note the locating point highlighted in red.
Pic 2: Press-fit the side panel 101C in place in the same way.
Pic 3: Turn the assembly upside down and fix the base 101A in place as shown with 4 x W screws.
Pic 4: Store safely for now.
STAGE 102:
Front right wheel – Dry tyre.
Pic 1: Retrieve the wheel from stage 99. The tyre 102A will fit onto it. You may find it easier to fit the tyre if you soak it in hot water for a few minutes. Dry the tyre inside and out and press it onto the wheel rim. Take care with hot water. The use of hot water is at the builder’s discretion.
Pic 2: Store everything safely.
STAGE 103:
Side deflectors.
Pic 1: Fix the deflector 103B to the front of the chassis as shown with 1 x Z screw. Note the locating pin circled.
Pic 2: Fix the deflector 103A to the front of the chassis as shown with 1 x Z screw. Note the locating pin circled.
Pic 3: Press-fit the panel 85A in place as shown.
Pic 4: Press fit the panel 85B in place on the other side.
Pic 5: Fix the panel 95A in place as shown with 2 x W and 1 x K screws.
Pic 6: Repeat on the other side with panel 97A.
STAGE 104:
Left side pod.
Pic 1: Retrieve the front car assembly and fit the head restraint from stage 8 in place.
Pic 2: Turn the assembly over and fit the side pod 104A in place as shown and fix with 5 x T screws.
Pic 3: Fix the support 104B in place with 3 x T screws.
Pic 4: Fix the support 104C in place and fix with 2 x T screws.
Pic 5: Store safely for now.
