Issue 5 Part 1
Picture 1 shows the parts for this issue. Fit the right front fender bracket and secure it in place using 2 x AM screws. Now do the same with the left-hand fender bracket, pictures 2 and 3.
Turn the model over so the right side is facing you. Attach the front fender from issue 2 making sure you clip the mounting discs on their posts, picture 4. Once in place apply a KM screw in the hole on the top of the fender on both sides as shown in pictures 5 and 6.
That completes the assembly for Part 1 of this issue.
Issue 57 Part 2
Retrieve the front wheel assembly you built early in the build and feed the wheel between the two forks, pushing the brake disk between the brake discs, pictures 7 and 8.
Take the front wheel axle and place it through the forks on the right-hand side as shown in pictures 9 and 10. Turn the bike over and secure the wheel using the axle bold, picture 11.
Turn the model back onto the right side and push fit the front brake calliper as illustrated in pictures 12 and 13.
Position the fork bridge over the holes in the calliper mounting and secure it in place using 2 x KM screws, picture 14. Attach a KP screw to the rear of the calliper, picture 15.
Connect the tube 48-0-2 to the calliper as shown in picture 16.
Issue 58 Part 1
Picture 1 shows the parts for this issue. Attach the tip to the bracket as shown in pictures 2 and 3. Take the assembly and place it onto the top of the upper air intake section. Secure it in place using 4 x BP screws, picture 4.
Add the left and right connectors to the connector bracket and secure each side using a BP screw as illustrated in pictures 5 and 6. Place the assembly onto the front bracket and secure using 3 x BP screws, picture 7. Now take the connector bracket and attach it as shown to the front bracket, picture 8. Secure in place using 3 x BP screws.
Now prepare the cables and cut to the lengths as shown in picture 9. 1 x 4cm 1 x 10.5cm 1 x 9cm 1 x 20cm 2 x 8cm 1 x 10cm
That completes the assembly for Part 1 of this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 58 Part 2
Having prepared the cables, attach the 4cm cable to the two points shown in pictures 10 and 11. Take the 10.5 cm cable and attach it as shown in picture 12 and 13. The 9cm cable attaches to the points shown in pictures 14 and 15. The longer 20cm cable attaches to the points shown in pictures 16 and 17. The first 8cm cable attaches to points in pictures 18 and 19. The second 8cm cables attaches to points shown in pictures 20 and 21. The final 10cm cable attaches to the points illustrated in pictures 22 and 23.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
