 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,880 Points: 17,792 Location: ipswich
STAGE 99:
Left Window net.
Pic 1: Carefully fit the net rods 99C and 99D to the net 99B as shown.
Pic 2: Fit the long rod 99D on the net into the locations on the interior as shown. Make sure the net is the correct way round.
Pic 3: Fit the shorter hooked rod 99C in place where indicated.
Pic 4: Fit the roll cage bar 99A in place as indicated. Highlighted in yellow. You will find it easier to temporarily remove the black interior vent hose to do this.
Pic 5: This shows the location of the front of the bar. Highlighted in yellow.
Pic 6: Fix from underneath with 2 x AP screws.
Pic 7: Replace the air vent hose.
Store safely for now.roymattblack attached the following image(s):
STAGE 100:
Roll cage rear braces.
Pic 1: Fix the brackets 100B and 100C to the brace 100A with 1 x TP screw underneath in each. The brackets are marked ‘L’.
Pic 2: Fit the assembled brace to the rear left of the roll cage as shown and fix with 1 x AP screw in each end.
Pic 3: Fix the brackets 100D and 100C to the brace 100E with 1 x TP screw underneath in each. The brackets are marked ‘R’.
Pic 4: Fit the assembled brace to the rear right of the roll cage as shown and fix with 1 x AP screw in each end.
STAGE 101A:
Mirror and cockpit fitting.
Pic 1: Stick the mirror 101C to the frame 101A and then attach it to the roll cage with 1 x XP screw.
Pic 2: Fit the cotter pin 101D to the fire extinguisher handle 101B as shown.
Pic 3: Fit the assembly into the bracket on the inner roll cage as shown and then attach the cable 78J.
Pic 4: Using the cable tie 101F attach the fire extinguisher hose 98h/I to the roll cage near the driver’s seat. Cut off the excess cable tie.
Pic 5: Press-fit the connector 101E to the rear right corner of the cockpit floor.
Pic 6: Retrieve the main car assembly and secure the outer exhaust to the chassis with 1 x EP screw . Pic 7: Remove the rear shelf 51D. Do not lose the 6 x screws.roymattblack attached the following image(s):
STAGE 101B: Pic 8: Position the cockpit over the chassis and reconnect the wires as shown. Refit the holder and screw that was removed in an earlier stage.
Pic 9: Wriggle cockpit into place on the chassis. Be patient here as it is a very tight fit and is awkward to get into place. Make sure the connecting points indicated (on both sides) are correctly located.
Pic 10: Fix with 3 x AM screws.
Pic 11: Repeat on the other side.
Pic 12: Fix the front firewall with 1 x EP screw. Repeat on the other side.
Pic 13: With the model on its side, connect the steering column and bracket with 2 x CM screws. This is very fiddly so patience is needed.
Pic 14: Fix the dashboard front with 2 x AM screws.
Pic 15: Refit the rear shelf.
STAGE 102:
Rear deck inner reinforcement.
Pic 1: Retrieve the boot lid from stage 4 and fix the bracket 102D in place as shown with 2 x AAM screws.
Pic 2: Press-fit the catch 102E into the recess on the inner panel 102A.
Pic 3: Fix the inner panel to the boot lid using 8 x AEM screws.
Pic 4: Fix the hinge parts 102B and 102C together as shown using 1 x AAM screw.
Pic 5: Fix the hinge to the bracket as shown using 1 x AAM screw.
STAGE 103:
Rear spoiler.
Pic 1: Press-fit the 6 x braces 103B into the spoiler 103A as shown. They will only fit one way.
Pic 2: Fix the spoiler to the boot lid using 6 x ABM screws in the loctions indicated.
Pic 3: Store everything safely for now.
