Toyota Supra F+F Issues 99 - 104 Options
#1 Posted : 17 November 2026 13:32:56
STAGE 99:
Rear window and hinges.
Pic 1: Retrieve the tailgate 99A and fix the hinges 99C and 99D in place with 2 x BM screws in each.
Make sure you fit each hinge on the correct side as shown.
Pic 2: Fit the rear window 99A by sliding the lower tabs in place first and then clicking the upper tabs in place.
The tab locations are highlighted in yellow.
Pic 3: Fix the screen with 2 x QM screws on the inside.
Pic 4: Store everything safely for now.
#2 Posted : 19 November 2026 10:16:01
STAGE 100:
Tailgate inner frame.
Pic 1: The following four steps are fitting the spoiler support brackets.
Look closely at the sprue of brackets and you will see they are all numbered 1 – 8.
It is important that you fit the correct brackets in each space and fix underneath with 1 x KP screw in each.
This step uses 100B-1 and 100B-5.
Pic 2: 100B-2 and 100B-3.
Pic 3: 100B-6 and 100B-7.
Pic 4: 100B-5 and 100B-8.
Pic 5: Fix pieces of self-adhesive tape 100C where shown.
Pic 6: Fix the LED wire in place as indicated.
Pic 7: Fix the frame 100A using 4 x IM and 2 x QM screws where indicated.
Pic 8: Fix the lower panel 99B using 4 x QM screws.
Store safely for now.
#3 Posted : 24 November 2026 18:05:35
STAGE 102:
Rear spoiler.
Pic 1: Lay the spoiler 102A in the position shown.
Fix the left brackets 102F using 1 x PP screw in each.
The parts are marked 'L'.
NOTE – The thicker bracket goes toward the other half of the spoiler.
Fix the right brackets 102E using 1 x PP screw in each.
The parts are marked 'R'.
Again, the thicker bracket goes toward the other half of the spoiler.
Pic 2: Fix the 2 x supports 102D using 2 x VM screws in each.
Note the direction of the supports as indicated in yellow.
Pic 3: Fix the end plate 102C using 4 x PP screws.
Note the direction of the spoiler support indicated in yellow.
Pic 4: Fix the other support in the same way.
#4 Posted : 26 November 2026 11:59:32
STAGE 103:
Left side skirt.
Pic 1: Fit the air intake parts 103B and 103C together as shown.
Pic 2: Fix the assembly to the skirt 103A with 1 x CP screw.
Pic 3: Fit the skirt to the car body.
Pic 4: On the inside, fix with 3 x CP and 1 x TP screws.
Pic 5: Retrieve the inner panel from stage 95 and fix it in place as shown with 2 x UM screws.
#5 Posted : 27 November 2026 10:10:06
STAGE 104:
Right side skirt.
Pic 1: Fit the air intake parts 104B and 104C together as shown.
Pic 2: Fix the assembly to the skirt 104A with 1 x CP screw.
This page was generated in 0.120 seconds.
