26 Pages «<1415161718>»
MWG build diary of the Bark HMS Endeavour Options
Silent_Running
#301 Posted : 19 October 2011 23:35:06
Lovely to see what she looks like planked, it gives me inspiration for my own build of Endeavour when I make a start. Keep up the good work Mike. BigGrin
#302 Posted : 19 October 2011 23:38:26
Thank you GlennBigGrin
#303 Posted : 20 October 2011 09:47:37
ISSUE 39
Hi everyone this morning I picked up this weeks issue from the newsagent, we have more planks and some good quality brass etching parts (yes I did say good quality:-
#304 Posted : 20 October 2011 09:54:15
Unfortunatly not much to do only make HINGES?
Next week we are receiving more planks and pins, and we are promised that we are going to use parts previously supplied to trim the upper edges of the ships waist and make the frame for the tiller hole - The Helmport Yippee!!!!!
No mention of the Bow and Stern formers, I will crack on with my own!!:-
#305 Posted : 20 October 2011 09:55:34
Thats all for nowBigGrin Cool
#306 Posted : 20 October 2011 19:22:12
I have started to cut the Bow and Stern Formers, here they are in their roughest form.
The small one is a better fit at the moment, but a lot more work required, comments welcome:-
#307 Posted : 22 October 2011 19:53:16
Lets continue with Balsa formers on the Bow, first.
I prepared 3 laminates of Balsa and here is what I did with -
#308 Posted : 22 October 2011 19:58:24
My trusty long bar is never far away.
Now to the Stern, this time just 2 laminates,then the whole assembly put away to dry, comments welcomeBigGrin
#309 Posted : 22 October 2011 20:38:56
Thats all for now!!!!!
#310 Posted : 22 October 2011 21:21:16
Great stuff mate..looking forward to seeing how it comes out...ThumpUp
#311 Posted : 22 October 2011 22:08:50
Thank you JonnyBigGrin Cool
alantait
#312 Posted : 23 October 2011 11:43:02
i agree its looking much better with your work on the bow and the stern, why they could not have finished all the planking i never knowConfused
current builds
#313 Posted : 23 October 2011 12:33:52
They should have have supplied the Bow and Stern formers weeks ago, I believe they are planned for weeks 42/43? thanks for your comments AlanBigGrin
#314 Posted : 23 October 2011 14:41:51
Here is an update of the Bow and Stern.
The enhancment is coming together well, I have half of the bow sanded and the other half not.Also I have had to put minor Balsa fillets in small gaps these will be sanded down when the adhesive is dry.
This has not been a major job and is very rewarding, comments welcomeBigGrin
#315 Posted : 24 October 2011 09:08:22
Drool Drool Those enhancements are looking real good. Looks like it is all coming together.Drool Drool
allanc62
#316 Posted : 25 October 2011 23:19:05
With regard to the etched parts, I was browsing the Eaglemoss website and found a comment from them stating that there is a mistake with the brass sheet supplied with part 39 in that there is only 7 hinge parts and not 8.
They say that there will another brass sheet in part 48
#317 Posted : 26 October 2011 00:23:23
strange that,7 hinges?I had 8 on my sheet,the hinges were in-line and were 7 the other 1 was a few pieces away tucked in amongst other pieces.
#318 Posted : 26 October 2011 10:19:03
Hi guys, have a look of the brass etching on my build post 303,looks like you could be right AllanBigGrin Cool
#319 Posted : 26 October 2011 13:12:48
sorry you are correct the hinges on the lefthand side only have 3 holes and the 7 have 4 holes,my mistake.
#320 Posted : 27 October 2011 11:24:41
FORMING THE BOW
I have finished shaping the bow and am pleased with the result,all I need to do now is finish the stern and sand the hull smooth ready fo the second planking :-
Guest (8)
This page was generated in 0.301 seconds.
