19 Pages «<1314151617>»
Magpie 1832's Surprise Build. Options
#281 Posted : 22 October 2011 20:58:31
Hi all,
Thanks guys, The clay i'm using is sculpey available from hobbycraft, its a polymer clay that has some flex in it after baking.it doesnt set until its been baked. Have u seen kids badges of animals or other colourful things that are plasticy those are usually polymer clay. It won't shrink either. Here's a link to their site.
http://www.sculpey.com/
I only used brass wire between the body and head also the body and limbs. Just to give a bit extra strength on those areas.
Give it a go stuart, I was the same as you but I sat there and thought i cant do a worse job than the supplied one. It took about 5 hours work to make.
Well worth it though. Its only £2-3 for some.
Chris
budgie
#282 Posted : 22 October 2011 21:14:05
BigGrin thanks for the confidence boost but think it is beyond my capabilities
silly thought
buy roman period plastic figures (used to be airfix something else now)
but still needs the old sticky out bits as i have only seen figure heads of females
Flapper unless their related to my mrs's and she's as tough as an old walnut
ps if she reads this any further correspondence please address to Victoria Hospital
#283 Posted : 06 November 2011 15:53:54
Hi All,
Here is a latest update, But thought I'd video the ship instead.. Watch in full HD 1080p Just click the 360p button once playing..
Chris...
budgie
#284 Posted : 06 November 2011 16:00:09
BigGrin cracking stuff Chris
builderphil
#285 Posted : 27 November 2011 14:38:17
Hi Magpie,been looking at your build of Surprise,can only echo what everybody else has said about you build quality.\have just received my first 2 editions for the Surprise,should have been 3 but never mind,would it be possible to use the Copper plates for the Victory,as i believe the Surprise was copper bottomed,also wouldn't mind your plans on the hull planking,at the mo im building Surprise,Ymato & Hood,& have just ordered the Victory,Cheers mate.Phil
#286 Posted : 27 November 2011 16:40:45
Hi Phil,
Welcome to the world of HMS Surprise.
Thanks for your nice comments.
The copper plates for the Victory build are a different scale so wouldn't fit the Surprise, I looked into it but couldn't find any of the right scale so chose bare wood.
The plans for planking, do you mean the ebook I have. If so PM me and I will send link to you.
Chris..
#287 Posted : 04 December 2011 23:29:40
Hi All,
Not done much since last time due too work and Christmas shopping (Blame the wifeFlapper Flapper ).
I have now finished the Beakhead, just need to drill the hole properly for the mast.
Chris....
magpie1832 attached the following image(s):
#288 Posted : 04 December 2011 23:35:52
BigGrin Very fine build there m8
#289 Posted : 05 December 2011 10:26:36
Thanks M8BigGrin BigGrin
#290 Posted : 05 December 2011 11:46:35
Fabulous build ChrisBigGrin Cool
#291 Posted : 05 December 2011 13:26:08
Thanks Mike BigGrin BigGrin BigGrin BigGrin
builderphil
#292 Posted : 07 December 2011 16:16:37
Hi Chris,like your Surprise,hope i can get somewhere near yours.Just received my decking,didn't get the nails with mine tho,every model i've worked on i've had this prob,if Admin are reading this take note,sorry Chris got sidetracked there for a mo,when you marked your deck for the planking did you measure from the Boe or Stern,cheers mate keep up the good work.Mellow Phil
#293 Posted : 07 December 2011 20:31:11
Hi Phil,
I measured from bow to stern along the centre line and got my planks to a measurement of 135mm.
Give this one a read..
http://forum.model-space.co.uk/default.aspx?g=posts&m=11654#post11654
It should explain how I came to the measurement.
Chris.BigGrin BigGrin
#294 Posted : 10 December 2011 16:43:32
Hi All,
Just a couple of pics of the Rudder hinges in progress. I decided to attempt to solder the hinges and am pleased with it.
Chris..BigGrin
#295 Posted : 10 December 2011 21:25:38
Nice enhancement ChrisBigGrin
#296 Posted : 11 December 2011 10:05:17
BigGrin Nicely done m8
Foz
#297 Posted : 11 December 2011 17:42:58
An amazing build you have there Chris. Keep up the great work.
Foz
#298 Posted : 11 December 2011 17:46:16
Your work is top notch as usual Chris, the hinges look great!! Drool
#299 Posted : 13 December 2011 00:08:55
Hi All,
Cheers Guys thanks for the nice comments.. I have now finished the Rudder assembly. Now its onto the Pin racks on the Bulwarks..
Thanks Chris..
BigGrin BigGrin
#300 Posted : 24 January 2012 19:33:43
Terrfic ChrisBigGrin enjoy. MikeCool
This page was generated in 0.480 seconds.
