26 Pages 123>»
Ian Smith Victory Build Diary Options
#1 Posted : 06 November 2011 19:07:06
Hi Guys
I have collected 83 issues of build the victory so far. As i am still finshing a radio controll model of the Bismarck, which is nearly compleated.
I thought i would make a start on the stern crest moulding of the victory
inbetween doing some bits of my bismarck.
attached are some images of the results.
#2 Posted : 06 November 2011 19:54:20
sorry guys my three year old nice has been pressing buttons on my p/c whilst i eas out of the room.
can any one please tell me how to delete the repeated posts Ian.Blink
tom.ganc
#3 Posted : 06 November 2011 20:50:34
Hi Ian, thanks for sharing. There is little problem with your second photo. It is completly out of focus. Could you retake it and repost it please? All details of your precision painting are gone becouse of this.
#4 Posted : 06 November 2011 21:28:41
Thanks tom, did not put my camera on macro.
hope second one is better ian.
#5 Posted : 16 December 2011 00:58:46
Hi guys
I am doing my Victory in the painted version, with copper bottomed hull.
i have started with the keel and ribs first as i have loads of issues.
I will be doing the Cannon, Anchor and the launch as a evenning project later on.
I have made the complete keel section and attached it to a build board.
also have made the ribs upto issue 12.
The ribs in attached photos are only dry fitted on the keel.
#6 Posted : 16 December 2011 01:10:38
Hi Ian, my that brings back memories,looking great Ian, I felt at this stage it helped to put Balsa Fillets In the Bow and Stern,and later on along the base of the Hull between the ribs, but then you know how I love BalsaBigGrin Laugh Laugh Love
#7 Posted : 16 December 2011 01:18:53
Thanks for the comments mike, any advise always welcome.
Cool
#8 Posted : 16 December 2011 01:22:17
How are the ribs have they rectified 12 and 15?
#9 Posted : 16 December 2011 01:33:39
hi mike rib 15 is short of the bottom of the keel will probably have to build it up slightly when get to fairing of hull. ( any hints or tips welcome)ian BigGrin
#10 Posted : 16 December 2011 11:06:49
Hi Ian, nice to see your build mate, it is looking good. As for rib 15, some of us found it necessary to build up the frame so that it was level with the keel...I used some spare 2mm x 3mm planking soaked in hot water for 20 mins or so then secured the wet planks onto the frame and allowed the planks to dry in place...then sanding it down even with the keel...
BigGrin
Enjoy your build mate...and keep the pictures coming...ThumpUp
#11 Posted : 17 December 2011 00:10:00
hi jonny
Thank you for the comments and information about building up rib fifteen
much appreciated Ian Cool
#12 Posted : 18 December 2011 18:59:15
Hi guys
attached photo of completed ribs up to issue 15.
#13 Posted : 18 December 2011 20:43:35
Good stuff IanBigGrin Cool
Foz
#14 Posted : 19 December 2011 18:55:18
Nice strt there Ian. Keep up the good work.
Foz
#15 Posted : 19 December 2011 19:41:18
Thanks for the kind comments mike and foz. BigGrin
#16 Posted : 24 January 2012 00:40:33
Hi guys
just a quick update on my build so far. i am still filleting between the ribs on my hull, i Will post some pictures later.
below a picture of issue 1 cannon.
Please feel free to leave comments, Ian
#17 Posted : 24 January 2012 01:31:36
Good work IanBigGrin Is everything going according to plan?Regards
MikeCool
#18 Posted : 24 January 2012 07:40:20
Looking good clean and tidy and as Mike says, brings back memories. Keep it up.
StefanDV
#19 Posted : 24 January 2012 08:46:34
Looking good Ian.
Is the cross-member of your Anchor the right way up? I thought the straight edge needs to be at the top?
#20 Posted : 24 January 2012 14:59:23
thanks for noticing that stefan. it should be other way up. good job i did not have to glue it. i should be able to remove the stock and turn it over. Ian Blushing
Guest (9)
26 Pages 123>»
This page was generated in 0.250 seconds.
