36 Pages «<89101112>»
MWG build diary of Nelson's HMS Victory Options
willie
#181 Posted : 14 November 2011 18:29:26
buy the way when i said used brass tube for the lanterns you only need to run one of the wires through the tube do not bare this one and use the tube as the second other words bare one of the wires right back to the bulb and attch it to tube in side the lantern at the top and at the bottom of the tube in side the model attch the 2core wire to it and the single bulb wire that comes out of the tube this in just case you wonder how can you get 2 wires down the tube small bore
#182 Posted : 14 November 2011 18:42:46
Thanks for the tip WillieBigGrin Cool
#183 Posted : 20 November 2011 18:38:58
THE GALLERY
I have decided to paint matt black on the bottem deck and area of this section,as the "heads" were port and starboard on the bottem deck of the Gallery, I thought it made sense
I will fit appropriate floor coverering on the deck above,with some subdued lighting, plus I like Trev`s (Tf64)table and chairsBigGrin Cool
#184 Posted : 20 November 2011 18:41:44
THE GALLERY
I will sand off the paint when it is dry, Questions and comments welcomeBlink
riff-raff
#185 Posted : 20 November 2011 21:22:33
MWG wrote:
Hi Team I have decided to light up the Gallery area and the lanterns on top, anyone got any ideas or thinking of doing the same, electrics are not my forte?BigGrin Cool
Have a look at my build - I used "grain of wheat" leds from CMB.
http://forum.model-space...t.aspx?g=posts&t=993
Built:
#186 Posted : 21 November 2011 01:34:31
Thank you for that RR Just the jobBigGrin Cool
#187 Posted : 21 November 2011 18:54:00
Hi MWG,
Your model to me is a fine example of how it should be done,like me you are still working on the gallery but I know it will be worthwhile in the end.I have layed floors and added bits here and there and will light it up as yourself,but still a long way back from the forum.
Regards tf64.
ps: can you tell me the size off the pictures you put into put into Photobucket ? is 640x480 correct.
#188 Posted : 21 November 2011 19:30:26
Hi Trev,
I do not use photo bucket I keep all of the photos in my laptop.
I plug in my camera, the photo wizard comes up, I have always the top highlighted (copy to a section of the computor) I then copy the photos to a particular album on my computor.
I then go to Micosoft picture manager (on my Computor) choose the album on my computor where I have stored the photos, and then resize them to 800 x 600
have I made sense?
I hope this helpsBigGrin Cool
#189 Posted : 21 November 2011 21:28:26
Hi MGW.
Thanks for your input I will try your recommendations.
Regards tf64.
#190 Posted : 21 November 2011 21:36:44
Hi Trev
Thanks for your nice comments by the way.
I will take forever with this build, I want to get it as accurate as I can, although I do realise there are limits, there are some great builds from some really good people, and I am learning from them every day, there are so many enhancements I want to do, the ships wheel, the binnicle, and other ideas I have in my head, most of all the Gallery enhancement. S o B has done the best gallery build so far,but it is still not right, the balustrades spoil it for me, we need an accurate gallery kit and I am even more determined to deliver that. If it takes 4 years to build my Victory so be it.
Your table and chairs is brilliant, I will be using that idea, if thats ok Trev? can you show me what you have done with the gallery decks?
Sorry If I have gone on a bit, I am so passionate about this buildBigGrin Cool
#191 Posted : 21 November 2011 22:43:18
MWG wrote:
Hi Trev
I am in the same mindset as you...
I will be making some considerable changes to the cabin area issue 57 in the next 2-3 weeks to improve the accuracy. i am scrapping the supplied cabin bulkheads and replacing with scratch built adding the doors and windows to the correct size and adding the pillars. There is also a raised cover for the steps behind the wheel i will be adding that. there is a lot of detail missing that is easy to fabricate at little cost. Still thinking about how i improve that horrid chimney LOL
#192 Posted : 21 November 2011 22:51:22
Jase PM me about the chimney.
I am glad it is not only me that feels the sameCool BigGrin
#193 Posted : 22 November 2011 00:52:37
Hi Mike,
Please be my guest with the table and chairs,I will post some more pictures of my gallery so you can see where I am.
Regards trev.
tom.ganc
#194 Posted : 22 November 2011 11:32:24
That's fantastic build MWG. I like your improvements and I can't wait for the gallery mod from you.
Looking at the boarding spikes set I'm sure it will be top quality.
Can't wait to see more pics.
#195 Posted : 22 November 2011 14:58:27
Hi Tom thank you for your kind words,The Gallery enhancement will be first classBigGrin Cool
#196 Posted : 23 November 2011 00:57:07
Hi Mike,
As promised just a few pictures of my Gallery todate,I still have a few more thoughts and jig's to make but I will keep to the mag and Mr T,I hope you can make out what I have done but with a resent visit to the Victory I was allowed to take a few shots inside Admiral Nelson cabin.
Regards trev.
#197 Posted : 23 November 2011 06:25:49
Thanks Trev, Good stuffBigGrin Cool
#198 Posted : 11 December 2011 03:36:33
Hi Team
Received ISSUES 79 - 80 - 81 - and 82.BigGrin Cool
#199 Posted : 14 December 2011 18:15:22
Hi Team received ISSUES 79 - 80 - 81 - and 82 todayDrool
Mr.Quist
#200 Posted : 16 December 2011 14:35:21
Hi Mike,
Can't PM you because your Inbox is full.
Please check your PM. THX !!
Timm
My build diary here
HMS Victory
Guest (11)
This page was generated in 2.965 seconds.
