Rope Holes Options
spity360
#1 Posted : 23 November 2011 11:01:17
I am at the stage on issue 43 where i need to drill the holes for the ropes
above the gun ports using the template the question is.. how deep should the holes be? i know the drill should be 1.5mm but no reference to the depth Huh
Thanks
Paul
#2 Posted : 23 November 2011 13:53:36
You can drill thru the planking as it won't be visble on the inside/reverse.
spity360
#3 Posted : 23 November 2011 18:20:01
Thanks mr t.
This page was generated in 0.046 seconds.
