56 Pages «<1617181920>»
MWG build diary of the mighty Hood Options
#341 Posted : 02 December 2011 21:45:35
I got my issue 14 on tuesday, so they were sent out early this week Tiz. I would get onto your Newsagent about it mate.
Chris..
S2ksean
#342 Posted : 02 December 2011 22:00:56
I'm having more problems aswell I still haven't got issue 13 come through then went down there this week only to find issue 14 is missing aswell so at the moment I'm two weeks behind. What a joke
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
S2ksean
#343 Posted : 03 December 2011 10:00:13
Looking good as always mike. Any idea what issue 15 has in store for us?
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#344 Posted : 03 December 2011 10:05:48
Hi Sean I think its more work on the stern cabin piece we have just completed at ISSUE 14'
Thank you for your nice commentsBigGrin
Tiswas
#345 Posted : 04 December 2011 21:03:22
You are not alone there Sean, I didn't get my Issue 14 either, this is the second time this has happened in a short space of time, wondering whether to take out a subscription?
Sorry to invade your topic Mike.
TIS
S2ksean
#346 Posted : 04 December 2011 22:11:25
I'm gonna see how things go for now but I think u might be right tiswas.
CURRENT BUILDS
Mclaren MP4-23
HMS Pandora
#347 Posted : 07 December 2011 11:39:49
ISSUE 15 CONTINUE WORK ON REAR CABIN STRUCTURE
This is what we received this week:-
#348 Posted : 07 December 2011 11:41:47
ISSUE 15
I numbered them as usual:-
#349 Posted : 07 December 2011 11:44:06
ISSUE 15
I then cut out the parts (cutting from both sides)trimmed and sanded them:-
#350 Posted : 07 December 2011 11:45:51
ISSUE 15
I left the 2 parts in the fret for later use as instructed:-
#351 Posted : 07 December 2011 11:47:55
ISSUE 15
Then I fitted the parts as instructed, to the completed build of ISSUE 14:-
#352 Posted : 07 December 2011 11:53:01
ISSUE 15
I then clamped the parts having used a set square beforehand, (this is the under side of the build):-
#353 Posted : 07 December 2011 11:57:31
ISSUE 15
And finally the topside of the build.
This has been put away to harden over night.
NOTE I have used extra glue,on the joins which will not be seen to give extra strength.
Questions and comments welcomeBigGrin BigGrin
#354 Posted : 08 December 2011 15:08:54
Hi Mike.
just a thought i have had looking at your last picture, the redoubt in the wall, how easy is your access glue to remove after it has dried, reason being that walls will probably have brass plates glued to the outside to show baulkhead details, as on my bismarck.
i know you have done this to strengthen the parts.
Hope you did not mind me mentioning this to you. Ian.
#355 Posted : 08 December 2011 18:08:11
Thanks Ian for the heads up regarding this area, I can remove adhesive if required, I certainly do not mind your comments it is very important to me to get feed back from my fellow modellers, so no problem keep the comments commingBigGrin BigGrin
#356 Posted : 08 December 2011 18:38:57
ISSUE 15
Hi Team this is how she looks now after ISSUE 15 buildBigGrin :-
#357 Posted : 08 December 2011 20:25:14
hi Mike.
i presume you use Alphatic sandable glue, ive just seen the yellow in some of the later pictures Ian Cool
#358 Posted : 08 December 2011 20:28:15
Ian you are spot on, its my favourite adhesive, its also waterproofBigGrin Cool
#359 Posted : 08 December 2011 20:45:00
i have bought some to use when i plank the victory thought it was worth it because it sands easily. ian Cool
#360 Posted : 08 December 2011 21:38:14
sorry to butt in here mike and ian,but I was under the impression that aliphatic glue was water soluble,and have on occations used water to free up gluing,unless there is one that is made waterproof,and is differently labeled to the normal one?
Guest (15)
This page was generated in 0.495 seconds.
