Joined: 10/01/2011 Posts: 91 Points: 273 Location: South Africa
Very nice clean build MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
It`s been a long time since my last post. But the fairing of the hull was very tricky (also family and job not allowing much time for the build). I had to reduce or build up almost every rib at some section - but now i`m happy with the result. In the meantime i also started the launch and the planking of the gallery supports - i`ll post those pictures in the next days (and hope someone is interested despite the fact that i`m so far behind the most of you!) DaDokta attached the following image(s): Greetings, Walter
Good Stuff MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Hi DaDokta your preperation is excelent im impresed with the time you have taken here to get it right it can save you many headaches in the future of the build as others have found out with certain ribs not seating properly.And remember your not behind anyone your just catching up with the other builders on here  , plus you have the option of perusing all the build diarys on here to see the problems others have encountered on the build and the actions taken to solve them. regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi DaDokta, nice clean build keep going it's looking good and heed the advice of the experts, saves you alot of grief later in the build. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
Very nice job MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Rank: Pro Groups: Registered
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Things are taking shape. Keep up the good work.
Happy building.
Athol
Thanks for your nice comments! This time i need your help,cause i don`t know if i`m doing the paintwork right. Now my questions: 1. I started with a coat of white primer - then sanding - next coat of white primer - then painting. I had the feeling, that the primer slightly changed the shade of the yellow ocre. Do you really need the priming? Or could you just sand the hull and then paint it? Or maybe paint it in the colour you want - then sand it down again - and put on a second coat of paint. Also i`m afraid that the lots of coats make the structure of the wood unvisible - i wouldn`t like to have it look like a plastic model. 2. Can i leave the hull now as it is - or should i put a coat of varnish on it. And if yes - i`ve got matt varnish, satin matt varnish and flat matt varnish (whatever the difference might be :)) - so which one should i use? I really would appreciate your advice. Thanks guys. DaDokta attached the following image(s): Greetings, Walter
Any ideas anyone??? Well then i guess i will have to try and error :) Greetings, Walter
Hi ,I like to use primer, and I think your use of same has achieved a very good result and the yellow colour looks right to me,avery nice build sir MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks, MWG. May i ask again if i should put a coat of varnish on the hull (matt or satin-matt?) or leave it as it is? Greetings, Walter
Hi, yes a coat of water based matt varnish would seal your work nicely MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thank you very much for your help, MWG. Greetings, Walter
So here`s an update with some pictures of my launch. I modified it a little bit, cause i wanted it to look more like the one, which is standing in portsmouth. So now for the planking of the Big one :) DaDokta attached the following image(s): Greetings, Walter
Spot on!! very nice job Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Nice looking launch you have there. keep up the good work.
Foz
 Spot on with the launch Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice launch, well done “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Joined: 19/03/2010 Posts: 602 Points: 1,679 Location: Lincs
A good solid looking start mate You do not need a parachute to skydive. You only need a parachute to skydive twice.
Built: Golden Star, English Brig. RMS Titanic. (Academy 1/400 Centenary Anniversary Edition) Revell-Monogram 1/48 B-29 Superfortress 1:8 Baron von Richthofen's Fokker Tri-plane. HMS Victory. Nelsons Flag Ship. Sultan Arab Dhow. Artesania Latina Carmen II. The Battleship Yamato. Model Airways Wright Flyer 1:16 Scale. Trumpeter Bismarck 1/200. HMS Sovereign of the Seas. The Black Pearl.
Guest (24)
