HMS Surprise Options
builderphil
#1 Posted : 08 December 2011 23:49:11
Hi happy band of bilder's how's things with your Surprise.I was hoping to say that i was getting on with my build,but unfortunatly i cannot.Started to put the deck plates on Wednesday,but that came to a crunching halt as nothing lined up,the deck plate cutouts didn't line up with the ribs,or the mast holes,can't believe the run of bad luck i'm having,hope there's a happy ending to this sorry saga.hope Admin read this.Bye gang,be back later with some good news i hope.PhilAngry
billbo
#2 Posted : 09 December 2011 11:24:43
sorry to here at hope you get it sorted mate
building the spitfire,RMS Titanic hachette and now starting the u-96 submarine
builderphil
#3 Posted : 09 December 2011 11:31:19
Thanks Bilboa,will keep you all up to date.Phil
#4 Posted : 09 December 2011 12:33:04
Hi Phil,
Can you post some photos of your build and memeber might be able to assist, I don't seem to recall Magpie1812 having such problems?
billbo
#5 Posted : 09 December 2011 14:37:39
Tomick wrote:
Hi Phil,
Iamm about to start mine soon hope I don't get at problem
builderphil
#6 Posted : 13 December 2011 21:13:53
Hi fellow shipmates,i had adelivery today containing the deck plates for the Surprise,and they fit 1st time,just had to trim about 2mm of the aft part of the stern decking but apart from that all went well,the only thing i didn't get were the nails,got some of my own,now the question is,what is the best way to put a nail close to the rib to hold the deck on the curve of the ribs,it could be that my pins are to long at 7mm,ant answeres greatfully received.Thanks,PhilBigGrin
#7 Posted : 13 December 2011 22:14:34
Hi Phil,
Best way is mark and centre line of each cutout, lay the front section of the deck in place, then pin in place from front to back a rib at a time always checking the centre line.
7mm pins are no problem mate.
Check on my build which way I have done it.
http://forum.model-space...s&m=11517#post11517
Chris.
builderphil
#8 Posted : 14 December 2011 11:07:08
Hi Chris,thanks for that advice will do that.Phil
This page was generated in 0.121 seconds.
