22 Pages «<56789>»
Stefan's build Options
StefanDV
#121 Posted : 30 November 2011 08:02:57
Thanks Karl,
That's clear ;) I'll get some photo printer paper. What size are your tiles? From your dairy I gather that you painted them after fitting?
StefanDV
#122 Posted : 09 December 2011 14:18:50
some more progress:
Real keel fitted:
I glued planking strips together and then sanded them to the required thickness to build wooden "in-fills" for the gallery support
Slots cut for the middle gallery deck
Tiswas
#123 Posted : 09 December 2011 21:31:15
Coming along nicely Stefan.
TIS
#124 Posted : 09 December 2011 23:53:13
hi stefan,I cut the tiles at 15mm x 5mm.I marked them up on 3 sheets of a4
phoyographic card,then used a pinwheel to get the rivets,try e_bay you need a fine tooth pinwheel.I got mine from a forum member(dorami)
StefanDV
#125 Posted : 15 December 2011 11:19:52
Thanks Gents!
A couple of more pics to show what I've been up to:
Where I sanded the hull back too much, some filler was required to smooth out the transition to the real keel
The gallery decks fitted & glued:
The rear gallery fitted & glued:
Inside view of the Gallery:
Foz
#126 Posted : 15 December 2011 18:59:49
Your build is coming along very nice thhere stefan. Great job
#127 Posted : 20 December 2011 09:44:29
Hi Stephan, your lady is looking nice and clean and coming on nicely. keep up the ggod work.
#128 Posted : 20 December 2011 09:46:45
Hi Stefan Great jobBigGrin Cool
#129 Posted : 20 December 2011 10:26:44
Great job Stefan...she is coming along really well mate...keep the pictures coming...ThumpUp
StefanDV
#130 Posted : 03 January 2012 09:16:08
Hi all,
Belated blessed Christmas and happy new year to all of you. Managed to get in a good couple of hours on the Victory during the time that I was on leave.
So as not to overload you, I'll post day-by-day pics of my progress:
Double planked gallery support:
Rear gallery former:
False bow deck fitted and shaped to accept the temporary mast:
#131 Posted : 03 January 2012 09:46:21
She is coming along brilliantly Stefan...ThumpUp
saintsman123
#132 Posted : 03 January 2012 15:22:21
fantasticaly clean and tidy build stefan, well done
Come on you Jimmies
#133 Posted : 03 January 2012 21:17:07
Great Matey keep it up Cool
#134 Posted : 03 January 2012 21:42:11
Well done StefanBigGrin
StefanDV
#135 Posted : 04 January 2012 08:08:12
Thanks lads!
As promised, some more action:
Getting a curve on the gallery side panels. It wasn't exact, but close enough to need only minimal adjustment on final fitting.
Fitting the gallery side panels:
I got cracking with planking the bow deck while the gallery side panels were curing. I didn't have a non-running marker, so I used a pencil to mark the edges of the planks
StefanDV
#136 Posted : 05 January 2012 08:23:44
Top mouldings added to the gallery sides:
The middle starboard wale pinned:
Bottom view of the Gallery sides and the rear of the middle wales. There is a slight gap which I'll be filling with wood filler:
The planks on the bow sanded down. I cut the opening of the dummy bowsprit dowel with a knife before sanding it, on the picture you can see that it was cut back too much. The middle 2 planks have since been replaced and the hole shaped properly
#137 Posted : 05 January 2012 08:42:22
Looks nice mate, Before Mr T says it... don't forget the extra hole in the bow. Flapper
StefanDV
#138 Posted : 05 January 2012 10:02:48
lol, thanks Jase!
I was under the impression that one had to wait until the trim strips have been fitted to the stem?
I'll get the cordless charging up!
#139 Posted : 05 January 2012 10:29:17
Nice crisp clean build StefanBigGrin Best wishes Mike
#140 Posted : 05 January 2012 10:38:14
Great work Stefan...Love ThumpUp
22 Pages «<56789>»
This page was generated in 0.182 seconds.
