Wales - double planked? Options
StefanDV
#1 Posted : 18 December 2011 11:34:56
From the instructions in issue 41 it sounds like the wales should comprise of 2 layers. Is this the case?
#2 Posted : 18 December 2011 13:22:59
Not in terms of two planks thick, but one plank laid above the other to form a double width, though 41 does not contain any instruction about the fitting of the wales, presumably you mean 42 Confused
StefanDV
#3 Posted : 18 December 2011 21:32:36
Thanks Tomick, you are correct, issue 42.
This page was generated in 0.025 seconds.
