All you need now is the engine sound
 Rank: Pro  Groups: Registered
Joined: 05/04/2011 Posts: 266 Points: 784 Location: Essexshire
Some lovely work there mate. How did you get the exhaust that colour, as thats what I want to do to the Mclaren
Joined: 27/07/2011 Posts: 99 Points: 293 Location: Marlow
My exhaust first was sprayed with white primer, Halfords then I used Mig powder on it, light rust, city dirt, and dust. I then over sprayed with very thin Humbrol satin black. However the colour of a Mclaren exhaust is stainless steel with burnt metal shading over, if your not sure I use thin clear red and thin clear blue, sprayed almost to nothing This gives a very feint shadow of hot steel. If you need more hel get in touch.
engine bay bigmal0 attached the following image(s):
 Good stuff Tony, it all looks very realistic, especially the brake servo and copper piping - excellent work. Keep the pics coming.   Kev
I was testing to see why my pics didn't come over properly. What an idiot I have been,reduced the size then published the Unresized, clever eh!
Good stuff Tony looking the business MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
A few more pictures of the Head and Carbs bigmal0 attached the following image(s):
 Nice work yet again Tony, you are really getting good at this methinks ?? Every time I see you have put up a new post I know before I even look, it's going to be a treat !! Keep up the good work.   Kev
This job is like Topsy, keeps growing. As I do one thing I see something else that needs doing. BTW thanks for all the comments, it keeps me going. bigmal0 attached the following image(s):
Having received parts 46Inside roof assembly, I am now keen to line it but having looked at it for awhile does any forum member know :why all the holes: and do we get interior lights. Any info would help a lot.
Hi Tony Your build is fantastic I love your engine Re the holes in part 46 the inside roof,rear morror and lights assembly.This will be hidden from view,inside the frame of the car,and they are used to fix the inside roof to the frame of the car, which we will receive in ISSUE 81. There are complicated stages in this build, where parts are built in assemblies then they come together when the main metal frames arrive. An example of this is the engine compartment which is not fitted to the frame in one piece, but in several pieces later on in the build, it is my understanding that anyone who has built this assembly now, will have to disassemble to fit it later,but do not take that as gospel. I will be building and enhancing more of this model when I have received the main frames,then I can see exactly where the brake pipes etc can be added.also I want to leather the doors etc, but I want to make sure the doors will close when fitted!!!!!!! To my knowledge Tony the interior lights are not designed to work, however we will discover this for sure later on in the build,then if not we can choose to enhance or not. I hope this post helps you in your build MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thats a bit of a shock not getting part 52 till next year. Looking at my parts list it says the roof, by which I assume they mean the diecast part is the next issue, or have I got it wrong. The whole thing seems so odd the way parts are sent, who else would send the chassis at the end of the build! I've never done any partworks before and find it very strange the way the things are distributed. Regards the engine compartment I cant see why it will need to be dismantled because that part and the interior fit together, so the front wings and main body fit over it much like any other kit wouldnt you think. If this is not the case alot of my work thus far will have been for nothing.
Hi Tony, Last Wednesday we received issue 49 so 52 will come 3 weeks later. next Wednesday (21st December) we receive ISSUE 50 which includes parts as follows Right fuel tank, Right fuel tank cover and the left fuel tank cover hinge. As I said in my last post Tony we build assemblies which we then fit to the main chassis units when they arrive. I hear what you are saying about the engine compartment, and I like you would think it would be a straight forward fit and may be it is, but I was told the the engine compartment fitted in sections under the wings, so I am playing safe over this area,but I did say dont take this as gospel,all I am doing is answering your questions to the best of my knowledge. If you require ISSUE details upto 85 I can furnish this,as you have have guessed I by my ISSUES from my newsagent. MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Thanks for getting back to me. As you may have seen some of my sub assemblies have got a bit complicated ha ha, so I'm just hoping that I dont have to take it to pieces. I am also building the Mclaren from Deagostini and this seems to follow a more regular sequence.
With regards delivery I had issues 48-51 plus LOVELY Aston Martin book, sadly not much on the DB5. I thought I would put up a few pics of the lining part done. bigmal0 attached the following image(s):
Good suff Tony MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Hi Tony, You are a talented modeller and should be very proud of what you are achieving. I for one am hoping that you don't have to dismantle some of your excellent work in the engine bay when it comes to fitting things together, would be such a shame to have to do that.  Kev
