hull finishes Options
benni
#1 Posted : 24 December 2011 16:22:32
Rank: Amateur Level 1
Hi folks...I've been out of action for a while. At last I've managed to find time to get back her,BigGrin but the issues have been piling up!
I've just finished lining the ports on the one side and am about to start the other.
Meanwhile I've been reading all that arrived ( I love the history and all the trivia as well as the details).
But i have a questionConfused ...I'm not there yet, but the instructions say that when all the planking is complete, the whole hull has to be sanded SMOOTH and, with FINE grain sand paper, otherwise the varnish will get into the grooves and go darker.
My intention has been, to try and give the model a slightly "weathered" look, and i intended to use a rough sand paper, and a small wire brush on my Dremel.
Will this DETRACT from the model???
I would appreciate some thoughts and comments...
thanks,Cool lowly ranked ensign benni.
Built: HMS Victory
#2 Posted : 24 December 2011 20:43:22
I suggest you lay a section of planking from scrap as a test piece so you can try your methods and ideas, what you don't want to do is use your model as the test piece.
alantait
#3 Posted : 24 December 2011 21:42:57
not sure with the dremmel, i have one and it made the finish quite rough, i ended up using a fine sandpaper, the finish i got with the dremmel tended to leave the surface very grainy, but i may have had a courser paper on it?
hope this helps
current builds
#4 Posted : 24 December 2011 22:30:34
I agree I think the drimmle will be too abrasive. doing it manualy may take longer but you do have much more control.
benni
#5 Posted : 24 December 2011 23:29:32
Thanx to all for their suggestions... yes I do think it a good idea to try it out before I mess the model up! And with the stains as well.
About the Dremel and wire brush: I think it WILL work, as after I posted my query I remember that when I started the build I had downloaded some topics. One was on "Ageing and weathering".
to quote a few points:
1)"Pre-Planning & Experimentation
When ageing and weathering, pre-planning is essential. You need to make the decision to age and weather before construction begins and it should be carefully thought out. To do this you'll need to experiment, but not on the boat!"
Agrees with your comments!
then it continues:
2)"Once you have the construction materials, experimentation can begin. Take some scraps that will not be used and glue them onto a board. These test strips will be used to determine exactly how certain paints and stains adhere to woods, fibreglass or plastic etc."
That's a good idea.. you now have a rigid surface to experiment on.
As regards the Dremel and wire brush:
3)"Cut up several test strips of wood and run over them with a wire brush attached to a drill. This exposes the grain and helps give a used and worn look. The variance in texture and colour is what you're looking for, particularly in deck planking. Deeper grooves will stain darker than untouched areas. Start with a soft or medium wire brush"
And now for something I never even thought of:
4)"And finally
Aged pieces don't have sharp corners, so gently round them off.
Cabin and deck boards shrink with age. Give them a bit more space to create older character lines.
Do all your wire brushing before the boards are glued to the boat.
seasons greetings and best wishes to all.
I hope this extra infoadds to our knowledge base.
benni.
Built: HMS Victory
