22 Pages «<678910>»
Stefan's build Options
Gerrit
#141 Posted : 06 January 2012 05:50:32
Awesome wok Stefan You should be proud
Gerrit
StefanDV
#142 Posted : 06 January 2012 09:25:03
Thanks gentlemen.
I hope it's ok to post pictures as I go instead of the finished product - of which there are much more worthy examples than mine.
3 strips of the lower wale pinned:
Bottom strip of the lower wale fitted. This was easier than I anticipated
Lower wale complete, upper wale pinned:
RussG
#143 Posted : 06 January 2012 11:55:22
Lookin Good Stefan, Keep it up
Happy Building, Russ
#144 Posted : 06 January 2012 20:38:49
Mooi so Stephan. Beauty in the making. Looking real good nice, clean and tidy. Keep it up
#145 Posted : 06 January 2012 22:31:00
Nice stern planking neater than mine LOL BigGrin
Atholm
#146 Posted : 07 January 2012 13:52:34
A lovely build,well done keep, us up to date.
Happy building
Athol
StefanDV
#147 Posted : 09 January 2012 09:30:17
Thanks all - I really appreciate your comments.
All 4 wales fitted, gun-port openings cut and the holes drilled for the gun-port lids: (I wish I took the time and made a jig to get the holes perfectly square to the gun ports - one or 2 that came out a little skew)
Little jig to assist with supporting the wriggles while marking & cutting:
Cutout of the wriggles complete:
#148 Posted : 09 January 2012 09:42:30
Very nice work in deed Stefan...great job mate...keep the pictures coming...ThumpUp
farrabass
#149 Posted : 09 January 2012 15:00:17
Very proffesional!
Looking very good.
Steve..
StefanDV
#150 Posted : 10 January 2012 08:11:10
Thanks Johnny & Steve!
The dolphins fitted and the Hawseholes drilled:
The stem trim:
3rd hole drilled in the stem:
#151 Posted : 10 January 2012 10:18:47
Fantastic Build StefanBigGrin
Mike
#152 Posted : 10 January 2012 13:41:13
Looks loverly. BigGrin Cool
StefanDV
#153 Posted : 11 January 2012 08:11:31
Thanks Mike & Jason!
I've started with planking the middle deck, but had to remove all the planks due to a measurement/marking error of the centre-line.
Below is a picture of a little jig I built to mark 13mm from the centre-line. I'm temporarily deviating from the official build in order to make the grates narrower as per Son of Bulwark.
Here is the first try:
And removed again
StefanDV
#154 Posted : 24 January 2012 08:51:18
Finally fished the deck planking over the weekend:
The fingers fitted
Decking right to the edge on the hull on the Portside bow
Space left at the back - as per the instructions
#155 Posted : 24 January 2012 10:59:33
Good Stuff as usual StefanBigGrin Regards MikeCool
StefanDV
#156 Posted : 24 January 2012 13:00:06
Thanks Mike! Some areas to be improved upon, but a very good preparation for planking the upper deck(s) that follows
#157 Posted : 24 January 2012 13:53:16
Nicely done Stephan, as usual a beautifull clean and tidy job. Well done.
#158 Posted : 24 January 2012 14:33:15
Great Stuff Stefan...She is coming along brilliantly!!ThumpUp
#159 Posted : 24 January 2012 21:46:23
great build stefan. thanks for the heads up on anchor. IanCool
#160 Posted : 24 January 2012 22:11:51
Hi Stefan,
Your build look as good as ever,great lines,great build looking forward to more pictures,well done.
Regards tf64.
22 Pages «<678910>»
This page was generated in 0.473 seconds.
