Make your own paper zero! Options
Louie
#1 Posted : 08 January 2012 17:43:55
Check the web page out looks like fun! just found it almost by accident.
http://www.ece.cmu.edu/~...irplanes/zero/index.html
#2 Posted : 08 January 2012 18:16:11
BigGrin Louie I am also collecting the Hachette Lancaster Bomber did you say there is a haynes Manual for this plane? Regards
Mike
Louie
#3 Posted : 08 January 2012 18:25:09
Mike
Yes there is I got mine off of amazon its got some good pics in there and some very interesting stuff, mind you the list of running cost's are a bit scarey so I wont be buying a real one!BigGrin
SennaMentalMe
#4 Posted : 08 January 2012 18:48:19
MWG wrote:
BigGrin Louie I am also collecting the Hachette Lancaster Bomber did you say there is a haynes Manual for this plane? Regards Mike
BigGrin Hi Mike,
Yes, Haynes have done a manual for the Lanc and very good it is too !! I have it and it is full of useful photographs and technical drawings, etc., though it is based on the current BBMF Lanc which has a lot of modern flight equipment fitted so don't take every fitting in the photos as being original to the way a Lanc looked during the Second World War. I believe that Haynes have also done a manual for the 'Dambusters' version of the Lanc as well. SAM Publications do an even better book in their 'Modellers Datafile' series which is aimed primarily at the modeller and has loads of detail photos and even more technical drawings.
BigGrin Kev
#5 Posted : 08 January 2012 19:37:16
Thanks Louie and Kev, for the infoBigGrin Regards Mike
This page was generated in 0.099 seconds.
