No Sean  I think you are more right than me. By the way you asked for photos of the Airfix Zero I posted some  Cheers Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Lol cheers il have a look CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
ISSUE 18 Hi Team here is how she looks now!:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Taking shape. starting to look like a ship. “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
IT certainly is Jase MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES Hi Team here we are again week 19. continuing with sub- assemblies on the deck. For this I just removed the deck section, rather than work on the whole ship. This is what we received:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES I numbered the parts, and cut them out, cutting from both sides of the fret:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES The parts as you can see are very "fiddly" it is worth taking the time to trim and sand them a little more than usual. I then assembled the parts as per the instructions ( At no point should the parts at this point be glued to the deck no 73) Here are the photos:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES At this stage I left the glue to dry.Then I must sand the corners of the sub-assembly, and finaly fit it to deck 73 using parts 101 and 102. Questions and comments welcome  Thanks for watching. Mike. MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES After the build this time she looks like this:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 19 DECK SUB-ASSEMBLIES The part we have built is then fitted and glued in place on Deck 73, at the same time fitting pieces 101 and 102 to anchor to other parts already fitted That all this time, thanks for watching  Mike MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
I have a question if I may. There are a number of ladders and doors on the superstructure you are just building. do you know if you get them or not? some are hard to see so they may be left off. build looks great by the way “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Jase questions are really appreciated There are brass etchings coming (I understand )that in some way cover the sub assemblies, but it is something I have not seen, its only been referred to in the magazine. Thanks for askinMikeg MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Hi Mike, Jase To answers jases question the bismarck i made had all the ladders between the decks and even ladders up the sides of bulkheads. i would think the hood would go into the same amount of detail on superstructor. Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great new Ian,  we have lots to look forward to! Cheers Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 20 BOW DECK PIECES Hi team the parts we have received this week on the fret are different to the ones depicted in the instuctions. Two parts (103) are missing from the fret but the way the other parts are configured it looks like they are not needed any way, but to be on the safe side I have made copies of these two parts, and fitted them. I will post the modifications I have done with photos later in the day. Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi Mike
Noticed that myself yesterday, I did ask the question wether anyone else had the problem. But my build log isn't showing. Glad it wasn't just my parts that were missing.
chrisOn the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
ISSUE 20 BOW DECKS Hi team I have spoken to Hachette who say the parts are indeed missing, and are to be included in a future issue. If in the meantime builders wish to progress, the missing parts can be easily replicated. I will show my mods this evening with photos Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
HMS HOOD ISSUE 20 BOW DECKS Hi Team this is my build diary as promised This is what we received:- The two items that should have been on the fret I replicated:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 20 Hi again Team, You will see I have replicated parts 103. You will also notice part 104 has a Half rib extrusion where it fits over rib 37 (the instructions show no extrusion on the part 104 at this point) Part 104 has a full rib extrusion where it fits over rib 39 (the instructions show half a rib extrusion at this point) Part 105 has no rib extrusion where it fits over rib 39 (the instructions show half a rib extrusion at this point.) I made a part I have called 104a to glue to part 104 in order for it to support the edge of 105 see the photos:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (25)
