51 Pages <12345>»
DaDokta`s Build Options
farrabass
#41 Posted : 30 December 2011 16:10:45
With regard to your last post, the planking that can be seen through the entry ports is in near darkness, so don't be to bothered about trying to perfect what you have already done so far.
Use the experience you have attained to go that step further on the next batch of planking that is required, the same will apply to the first set of cannons required for the next deck, do the best you can and then look at the finish and hopefuly you will see what needs to be improved upon or can be done in an easier or quicker way for the ones on the main deck which will be very visible and should be your best examples.
But you should be taking heart from what you have done so far, as what you have done looks realy good!
All the best Steve..
DaDokta
#42 Posted : 13 January 2012 09:11:01
First pics of the planking of the gallery supports:
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#43 Posted : 13 January 2012 09:58:10
Coming along nicelyBigGrin Good work.Cheers Mike
#44 Posted : 13 January 2012 10:16:16
Your build is coming along very nicely...Keep the pictures coming...ThumpUp
Foz
#45 Posted : 13 January 2012 11:39:40
Good looking build. Keep up the good work.
Foz
#46 Posted : 13 January 2012 13:42:02
Keep going she looks good and clean and fresh.
StefanDV
#47 Posted : 25 January 2012 13:44:18
Looking very good - well done!
#48 Posted : 25 January 2012 14:17:51
Good stuff, Great build DakotaBigGrin Regards MikeCool
benny
#49 Posted : 25 January 2012 21:23:02
very neat and tidy,nice job
cheers benny
#50 Posted : 25 January 2012 21:37:35
looks great Cool
DaDokta
#51 Posted : 08 February 2012 16:59:29
The first row of gunports is complete:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Atholm
#52 Posted : 09 February 2012 16:15:54
Coming on very nicely, keep up the good work
Happy building
Athol
DaDokta
#53 Posted : 26 February 2012 19:11:51
Here`s an update. Finished the bow upwards. Despite the fact, that i didn`t realize that some of the planks are not of the same width troughout the length, i´m really happy with the result. I will have to use some wood-filler here and there.
Now for the gun-ports of the middle-gun-deck :)
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
saintsman123
#54 Posted : 26 February 2012 19:54:43
Good work dadokta
Come on you Jimmies
#55 Posted : 27 February 2012 13:21:36
She is beginning to take shape, good work keep it up
DaDokta
#56 Posted : 04 July 2012 09:10:40
It`s been a while since my last post. I was busy planking the hull below the waterline.
First i had to build a jig - i used dummy masts to turn the ship upside down.
Here are some pics of my progress.
The next planks would be the garboard planks - but if i added them, i would not be able to put her back into my "Upright" - jig.
So i stopped here and turned her over again - i will now build the upper gun deck and finish the hull planking above the water line.
Greetings from Austria,
DaDokta
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
pierre50
#57 Posted : 04 July 2012 09:48:38
Looking great mate!
Current Buid:
HMS Victory
Next Build:
Captain Cook's Endeavour Collecting issues
Wish List:
Santa Ana
Bounty
Santisima-Trinidad
#58 Posted : 04 July 2012 09:50:12
Well done!! She is looking great!! Keep the pictures coming...Wink ThumpUp
#59 Posted : 04 July 2012 12:06:29
She's looking great. Keep up the good work and the pics coming.
DaDokta
#60 Posted : 06 July 2012 10:28:29
The upper gun deck:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Guest (12)
51 Pages <12345>»
This page was generated in 0.347 seconds.
