With regard to your last post, the planking that can be seen through the entry ports is in near darkness, so don't be to bothered about trying to perfect what you have already done so far. Use the experience you have attained to go that step further on the next batch of planking that is required, the same will apply to the first set of cannons required for the next deck, do the best you can and then look at the finish and hopefuly you will see what needs to be improved upon or can be done in an easier or quicker way for the ones on the main deck which will be very visible and should be your best examples. But you should be taking heart from what you have done so far, as what you have done looks realy good! All the best Steve..
First pics of the planking of the gallery supports: DaDokta attached the following image(s): Greetings, Walter
Coming along nicely  Good work.Cheers Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Your build is coming along very nicely...Keep the pictures coming... Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Good looking build. Keep up the good work.
Foz
Keep going she looks good and clean and fresh. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
 Rank: Pro  Groups: Registered
Joined: 07/01/2011 Posts: 399 Points: 1,212 Location: Penhill Estate, Western Cape, ZA
Looking very good - well done!
Good stuff, Great build Dakota  Regards Mike MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
very neat and tidy,nice job cheers benny
looks great “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
The first row of gunports is complete: DaDokta attached the following image(s): Greetings, Walter
Joined: 15/09/2010 Posts: 175 Points: 517 Location: Durban RSA
Coming on very nicely, keep up the good work
Happy building
Athol
Here`s an update. Finished the bow upwards. Despite the fact, that i didn`t realize that some of the planks are not of the same width troughout the length, i´m really happy with the result. I will have to use some wood-filler here and there. Now for the gun-ports of the middle-gun-deck :) DaDokta attached the following image(s): Greetings, Walter
Joined: 30/01/2011 Posts: 865 Points: 2,410 Location: Cambs
Good work dadokta Come on you Jimmies
She is beginning to take shape, good work keep it up Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
It`s been a while since my last post. I was busy planking the hull below the waterline. First i had to build a jig - i used dummy masts to turn the ship upside down. Here are some pics of my progress. The next planks would be the garboard planks - but if i added them, i would not be able to put her back into my "Upright" - jig. So i stopped here and turned her over again - i will now build the upper gun deck and finish the hull planking above the water line. Greetings from Austria, DaDokta DaDokta attached the following image(s): Greetings, Walter
Joined: 11/09/2011 Posts: 227 Points: 677 Location: Heidelberg South Africa
Looking great mate! Current Buid: HMS Victory Next Build: Captain Cook's Endeavour Collecting issues Wish List: Santa Ana Bounty Santisima-Trinidad
Well done!! She is looking great!! Keep the pictures coming...  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
She's looking great. Keep up the good work and the pics coming. Rgds, Hans "It's okay to make mistakes. mistakes are our teachers - they help us to to learn, even if it is painfully" Current Build: Endeavour Cross section,D51 Completed: HMS Victory Under the bench: Endeavour x 2,Sovereign of the Seas, Akagi and The Black Pearl!HMS Victory Cross Section
The upper gun deck: DaDokta attached the following image(s): Greetings, Walter
Guest (22)
