Studdingsail Irons Options
#1 Posted : 13 January 2012 15:36:40
Hi there shipmates...I ran into a little problem when I reached Issue 65 and the construction of the main yard...I had drilled the holes in each end of the yard and dry fitted the studdingsail boom irons...it was then that I found that one of the boom irons was slightly warped (the thin part that goes into the hole)and throws the studdingsail boom out of line with the main yard. Has anybody else come across this problem, if so, how did you get round it, as I know that the metal is very brittle and cannot be manipulated?
Blink Confused
willie
#2 Posted : 13 January 2012 16:16:52
have you tryed drilling the hole at an angle to suit the offset you can strighten them but you got to be gentle very gentle a little at a time
#3 Posted : 13 January 2012 21:39:58
I haven't had this issue but agree with above try and offset the hole to take the male part.
RussG
#4 Posted : 13 January 2012 22:43:54
Hate to say it !!! Customer Services !!! and request a replacement BigGrin
Happy Building, Russ
This page was generated in 0.370 seconds.
