painting my hull Options
budgie
#1 Posted : 22 January 2012 11:53:11
Blushing Hi guys i would like to call on your advice
if everything goes tiddlyboo i will have a WALNUT hull which is supposed to be painted WHITE
BigGrin so i need to paint it white
Crying but still make it look like planking and not fibreglassCrying
Confused do i give the hull a coat of danish oil to protect wood
Confused do i use sanding sealer then paint
Confused Confused what is the differtence between undercoat and paintConfused
in short i have a dark hull to be painted white but i still want it to look like planking
There are posts looking at this but i am scared as once you put brush to paint there is no turning back
Crying adviseCool help Drool please
#2 Posted : 22 January 2012 12:50:45
Hi Budgie
My swift is also supposed to be painted white on the lower hull too, but iv decided to use danish oil only on mine as its a nice wood used for the planking.On your model the mahogany will come up a treat if you do this aswell.But if you decide to paint then 2/3 coats of sanding sealer and a good sanding after will prepare the surface for a white undercoat ect. Hope this helps.
#3 Posted : 22 January 2012 15:18:22
hi bodge,seems a shame to paint her,but if you do decide to paint.I will go into a little more detail,prepare the hull thus,a good fine sanding 600 grade,a thin coat of white undercoat to seal the grain,then a good rub down with 600 sand paper,this is to check for high spots,fill or sand until no more high spots,which means that all the paint has been removed,and every thing is smooth and level,(no high spots ect.then another coat of thinned down undercoat.sand with 800 grade wet & dry done wet.wipe down and when dry apply a normal coat of undercoat,another wet and dry session,then top coat,lotta work,if you want the finish you need tlc,elbow grease and a bit of patience.#83 Posted : 01 December 2010 10:07:38
check my post of the cutty sark,painting the hull white was a balls up,and I had to strip it off,as you will see.
budgie
#4 Posted : 22 January 2012 15:57:14
BigGrin thanks for your input guys
Drool @Karl very much glad u r still keeping an eye on us sprogs
cheers matey
This page was generated in 0.098 seconds.
