26 Pages <1234>»
Ian Smith Victory Build Diary Options
Dontshootme
#21 Posted : 24 January 2012 16:08:23
Ian,I hate to add more to your work but the gun carriage is incorrect as well,the wide part should be the breach end.
saintsman123
#22 Posted : 24 January 2012 18:00:16
not according to issue 1.
i'm sure when i went on victory they were all straight anyway, that is the same thickness front and back, and the ones on victory did not have cut out lines along the sides. which tells me that it makes no difference which way you put the thick end, just as long as you keep them all the same on you own model
Come on you Jimmies
Dontshootme
#23 Posted : 24 January 2012 19:03:31
There was much discussion in the early days of the build,the gun carriage is wrong in the mag,there wouldnt have been deep cut lines down the sides,& should be wider at the breach.
#24 Posted : 24 January 2012 20:04:24
hi guys
issue 1 shows the plank the way the cannon was made. all the follow on issues with cannons show the plank the opposite way.
i quess the superglue remover will be coming out.
Thank you all for your comments Ian BigGrin
#25 Posted : 24 January 2012 21:07:27
hi guys
The Anchor has been corrected Thanks stefan.
the Cannon is undergoing restoration.
Thank you all for your coments Ian BigGrin
StefanDV
#26 Posted : 25 January 2012 08:10:35
It's always a pleasure to be able to help out a fellow shipmate! BigGrin
I sometimes wonder what the guys do who don't post build dairies
Atholm
#27 Posted : 27 January 2012 16:02:13
Regarding rib 15 I found that the rib had to be lowered by filing the slot approx 1,5mm deeper. Check the deck support lugs are in line if they are, your solution is correct.
Happy building
Athol
#28 Posted : 27 January 2012 16:42:32
hi Atholm
Thanks for the information will check both options before fitting decking and fairing hull, Ian Cool
#29 Posted : 12 February 2012 22:46:59
Hi all
just a quick update on my build so far.
Carronade completed with cut out slide groove.
The launch has been built up to issue 10 iwill post some pictures of the laucnch when completed.
The keel and ribs have been filleted and require a little more sanding down.
#30 Posted : 13 February 2012 00:14:00
Looking great IanBigGrin Regards MikeBigGrin
#31 Posted : 14 February 2012 14:05:43
Thanks mike. Cool
#32 Posted : 09 March 2012 00:14:35
Hi Guys
An update on my Build so far.
Completed the launch
#33 Posted : 09 March 2012 00:18:14
Hull up to issue 19. Next step Fairing the hull.
#34 Posted : 09 March 2012 00:21:27
Middle gun deck, planked with some of cuts of teak, 1 x 3mm planks.
#35 Posted : 09 March 2012 03:38:52
Very good solid build IanBigGrin Regards MikeBigGrin
StefanDV
#36 Posted : 09 March 2012 07:47:39
Well done Ian, she's looking ship-shape!
#37 Posted : 09 March 2012 14:15:00
You are on the right track there Ian. Sterling job so far
#38 Posted : 09 March 2012 16:54:17
Thank you for the coments Mike, Stefan and Hans much appreciated IanBigGrin
#39 Posted : 09 April 2012 21:42:50
Hi Guys
Just a quick update to my build, The planking has been done for the first six rows, The lower gun ports have been cut and the stern gallery planking has been shaped. up to issue 24 in the magazine.
Son of Bulwark
#40 Posted : 09 April 2012 22:07:28
Hi Ian! Cool
It looks great mate! I would like to ask is it possible for you to take a picture of the stern from the side to check the side profile of the transom and false keel.
Darron
26 Pages <1234>»
This page was generated in 0.722 seconds.
